D3PE PROSPEED Dual Spal Fan Shroud Kit with PWM Speed Control!
#62
Received 1,194 Likes
St. Jude Donor '15
It should if you are using a full rad with the lowered radiator stay, but we have not verified, with that said, if you are running a Dewitts rad, these do not fit as the header to header length is shorter then OEM, also if its cut down, it also will not fit.
I will try to make an engineering drawing with overall dimensions to allow for space checking on custom supercharger setups.
#64
St. Jude Donor '15
For me personally over 225'ish I'd start doing cooling system upgrades such as this fan setup.
#65
Id like a Dewitts with the best fans possible. Holiday weekend so cant call anyone lol.
#67
They already posted pictures and confirmed that, so not sure why people are still asking.
#68
St. Jude Donor '15
Indeed
#69
My D3 fans are supposed to arrive tomorrow! I cant wait to get these installed
#70
Going to run them with stock radiator? I'm thinking of trying it with my stock radiator and see how it does....not having cooling issues....but always better to run a bit cooler as I'm planning to pulley down and power up soon
#71
Yes on stock Z06 radiator. Several people told me that they've seen great cooling performance with these fans on stock radiator. We shall see
#74
#75
I have mine installed and in the 108 degree heat yesterday my car sat idling in the garage and only got up to 185 degrees after 10 minutes. I have the TTIX turbo kit and the car previously ran really hot. I took it out in the same 108 degree heat and after about 15 minutes the car didn't exceed 203. I did not try to drive in stop and go traffic so I cannot attest to what my temperatures will do there.
My car had the factory fan and would run 225-230 in the same circumstances as above. I still have the stock radiator and did not change anything but the fan(s). As of now I am very impressed with this fan setup. I had an issue with the harness and the guys at D3PE were great to work with and resolved the issue quickly. This was a great investment!
D3PE (07-19-2016)
#76
I have mine installed and in the 108 degree heat yesterday my car sat idling in the garage and only got up to 185 degrees after 10 minutes. I have the TTIX turbo kit and the car previously ran really hot. I look it out in the same 108 degree heat and after about 15 minutes the car didn't exceed 203. I did not try to drive in stop and go traffic so I cannot attest to what my temperatures will do there.
My car had the factory fan and would run 225-230 in the same circumstances as above. I still have the stock radiator and did not change anything but the fan(s). As of now I am very impressed with this fan setup. I had an issue with the harness and the guys at D3PE were great to work with. This was a great investment!
keep us posted soon as you get a chance to test it out.
#77
Former Vendor
#78
Im running the fans with a Dewitts radiator on a 427 TT setup. It was running about 100 deg over ambient temp but would still shoot up to 230-235 with the A/C on. I went into the tune and changed the fan specs with the A/C on to command 100% instead of the 90% in the factory tune and it made a huge difference. I have not broken 220 since even with the A/C on. My Evans water pump should show up this week and hopefully help me get an even better control on these temps.
#79
#80
Your fan setup on a Dewitts full size radiator. Air to Air intercooler. Kicking the fans on earlier with on the A/C pressure table seems to really have helped keep the temps down with the A/C on. These fans are working hard to keep the temps down with the A/C on in this 100 deg Texas heat but its way better than the previous setup I had.
Stock:
Modified:
Stock:
Modified:
