fuel system
Jun 16, 2015 | 03:29 AM
fuel system
what fuel system kit do you guys like I have the ecs1500 needing one to handle over 900hp. and what's a good price for labor to install the kit.
Jun 16, 2015 | 05:06 AM
You won't make 900+hp on the Novi 1500. The ECS stage 1 fuel system will fit your needs.
Jun 16, 2015 | 07:43 AM
St. Jude Donor '13
Quote:
Originally Posted by
winters97gt
What he said............
Jun 16, 2015 | 09:42 AM
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Technically... it can make 900 hp flywheel.
Labor for the stg 1 fuel system is about 4-5 hrs.
Jun 16, 2015 | 09:43 AM
Only systems to look at IMO are ECS or Fore
ECS if you don't want to drop the tank, and fore if you don't mind dropping the tank.
Jun 16, 2015 | 11:10 AM
car made 850 put ran out of fuel
Jun 16, 2015 | 01:10 PM
I plan on spraying the car before September also
Jun 16, 2015 | 01:11 PM
Fore is the only system that you would need.
Jun 16, 2015 | 02:09 PM
Been researching fuel systems for way too long. Fore kit is definitely the way to go in the long run. Its a bit pricey but will be your best option for higher horsepower levels. Youre looking at 2k + for the kit depending on what you go with and about another 1k for install.
