Are you planning to keep working BCM and factory instrument cluster plus ABS and Active handling system if Motec?
no sir, all that is getting gutted out. running a c127 dash, deleteing abs and the brake booster will have manual brakes and a manual steering rack in it. all electronics outside of the motec will be controlled with a pdm unit.
Sounds good!! The way getting OEM stuff working conjuction with Motec is truly pain in the a*s as stand alone. I had to went development ecu instead GPR software and still few issues under work getting BCM and instrumental cluster work as OEM.
