C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Big twin teaser
Old 06-24-2017, 01:30 AM
  #141
BoostedC3
BoostedC3's Avatar
That's wicked! congrats!
Old 06-24-2017, 09:46 AM
  #142
schpenxel
schpenxel's Avatar
Received 1,195 Likes on 1,053 Posts
St. Jude Donor '15
That is insane. Congrats!
Old 06-25-2017, 03:19 PM
  #143
neverstop
neverstop's Avatar
so insane. can't believe you hit that speed while leaving so soft. get some gopro video!
Old 06-26-2017, 08:09 AM
  #144
ExoticMotorClub
ExoticMotorClub's Avatar
Nice job! Would love to see some footage.
Old 06-26-2017, 05:18 PM
  #145
FNBADAZ06
FNBADAZ06's Avatar
Wow !!!!
Old 06-26-2017, 08:19 PM
  #146
ace32x
ace32x's Avatar
I hate using go pros pros so I don't lol. 1320 got some good Incar footage of the faster passes. I think they're going to be posting something
Old 06-27-2017, 01:24 PM
  #147
bmfvette
bmfvette's Avatar
Bumper cover turned out real nice. Must be doing it's job as well pushing air around the car. Did it feel like the nose wanted to lift at all?
Congrats on the numbers!
Old 06-28-2017, 10:18 AM
  #148
Turbo-Geist
Turbo-Geist's Avatar
2017 C5 of Year Finalist
Nicely executed.
Are you running a front engine plate only with motor mounts or is there an engine plate on the rear of the block, too?
Old 06-28-2017, 07:51 PM
  #149
ace32x
ace32x's Avatar
Originally Posted by Turbo-Geist
Nicely executed.
we did a front plate and a mid plate
Old 06-29-2017, 05:56 AM
  #150
bill mcdonald
bill mcdonald's Avatar
I guess the twins help on sucking up the frontal area. Interesting to have the turbos mounted at that angle.
What about the stock naca duct and the quarter panel brake ducts. I would imagine at the speed you are going, they are not the best aero to have?
And a diffuser too. Whats the story on that? Have not seen a top speed car run one.
Old 06-29-2017, 08:19 PM
  #151
ace32x
ace32x's Avatar
Best fitment spot we found to get the twins in at was right there.
Thise ducts definetly do not help. Want to seal those up me pull the mirrors and cap those holes aswell.
Diffuser is part of the sealed underbody and helps with keeping the car stable and increasing air speed exiting the rear.
Old 06-30-2017, 01:56 PM
  #152
Milan
Milan's Avatar
lol wut? the top mile ford gt has always had a diffuser
Old 07-05-2017, 05:07 PM
  #153
ace32x
ace32x's Avatar
some coverage from the event with some outside and incar vids
The following 2 users liked this post by ace32x:
gotjuice? (11-01-2017), IMXCITD (02-17-2018)
Old 07-05-2017, 09:20 PM
  #154
neverstop
neverstop's Avatar
you're going to smash that other record.
Old 07-07-2017, 10:31 AM
  #155
BoostedC3
BoostedC3's Avatar
Congrats on the record!
Old 07-14-2017, 11:45 AM
  #156
TracyRR
TracyRR's Avatar
Awesome! Congrats on a great build
Old 07-15-2017, 03:01 AM
  #157
chuntington101
chuntington101's Avatar
Car looks amazing! Loving the rear diffuser.
Any reason for only 10:1 comp. ratio with the meth? Is that not hurting spool times with the big turbos? Any plans on running rolling anti lag to help light them off?
To Big twin teaser
Old 07-17-2017, 02:11 AM
  #158
ace32x
ace32x's Avatar
didnt need to get to crazy with compression because we plan to run a good 50 or so + lbs through it. have to get the converter sorted first before we can do any of that. anytime you run any kind of antilag (pulls timing and dumps more fuel in) you loose torque on the motor. which in the case of a converter car is no good. on a clutch car it doesnt matter.
got a M&M external trans pressure dump that i threw on the 400 that should help alot lowering the charge pressure and basically loosening the converter up when its open. will set that up with the trans brake, and i just added a dry fogger nozzle from N20 on it. with the converter loosened up from the dump we can run the antilag on it and hit it with a small shot to spool everything up and getting the party rolling on the line
Old 07-17-2017, 04:22 AM
  #159
chuntington101
Awww see the problem! Sorry should have thought of that.
Sounds daft but could quick spool valves help? Its another thing to fail I guess and would require hotside redo. But might help....
Old 07-17-2017, 10:49 AM
  #160
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Just 50psi? psst.
Quick Reply: Big twin teaser
