C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Car updates
Old Oct 19, 2015 | 05:16 PM
  #261
neverstop's Avatar
neverstop
hood looks awesome that way.
aside from reverse, any feedback on shift quality or smoothness etc on the t56 vs. the tr6060? just curious
Old Oct 19, 2015 | 05:18 PM
  #262
Unreal's Avatar
Unreal
It is notchier. Honestly I like the t56 more from a shifting stand point. Pretty sure reverse solenoid is working, just takes more effort.
50 miles on it now. Drove it to work, and to lunch, and around town.
Old Oct 20, 2015 | 10:58 AM
  #263
neverstop's Avatar
neverstop
interesting. that's good feedback. the built t56 in my car is not quite as smooth or fast as the stock tr6060 with stock clutch in my buddies 600whp 2008 vette but I also just found out my mcleod twin disc clutch was on its last legs.
even though my built t56 has like 2k or 3k miles on it tops i did notice improvement in shift feel when i put new amsoil in it too so not sure if you put new fluid in it during the swap but maybe worth a try if the notchiness bugs you
Old Oct 20, 2015 | 11:29 AM
  #264
Unreal's Avatar
Unreal
Yes it has new fluid in it.
Honestly there is very little difference between harder to hit 5/6/reverse. If someone had a t56, I wouldn't go out of my way or spend $3k+ like I did to swap. Nothing wrong with a t56.
Old Oct 20, 2015 | 04:17 PM
  #265
Blackonblacksls's Avatar
Blackonblacksls
Every time I say that, someone looses their **** and tells me the tr6060 is a way better trans and such a huge improvement. Ect, ect, ect.
Old Oct 20, 2015 | 04:24 PM
  #266
Dude_man's Avatar
Dude_man
I noticed a huge improvement between my 05 t56 vs the tr6060 I swapped in from an 08z06. Could be my t56 was just messed up but at the time the car was stock with only 50k miles on it.
Old Oct 20, 2015 | 04:44 PM
  #267
Unreal's Avatar
Unreal
Sure a broken old t56 compared to a new 6060 makes sense. If anything the 6060 shifts worse until warm.
Old Oct 20, 2015 | 04:52 PM
  #268
Dude_man's Avatar
Dude_man
Maybe I worded that wrong. There was nothing wrong with the t56 that I knew of. I swapped because I got a really good deal on a z06 drivetrain.
My tr6060 was a lot smoother than my t56, but you are correct on it getting smoother once warmed up.
Old Oct 20, 2015 | 05:05 PM
  #269
Unreal's Avatar
Unreal
Strange. I wonder what if anything can change. Fresh fluid? Changed fluid? Building it? Mine is a built up 6060 from RKT, triple carbon syncros and all that, so maybe that makes it notchier.
Old Oct 20, 2015 | 05:15 PM
  #270
Dude_man's Avatar
Dude_man
I did amsoil when I put it in. Mine is completely stock so that could be it.
Old Oct 20, 2015 | 05:17 PM
  #271
Blackonblacksls
Same shifter?? Or z06 shifter??
I've noticed a bigger difference swapping shifters than I have swapping transmissions.
Old Oct 20, 2015 | 05:21 PM
  #272
Unreal's Avatar
Unreal
Same shifter. MGW. It is notchy no matter what. Thinking of putting stock back on or trying the new hinson one out.
Old Oct 20, 2015 | 05:29 PM
  #273
Blackonblacksls
I've had 3 t56s cars and 2 6060 cars.
T56 in my 06z06 was the smoothest of the all.
But it's also the only one I've actually broken. Even though it did last over 100k miles..
Tr6060s just seem a bit notchier and if you drive them hard seem to round off the synchros pretty quickly, as I believe they are smaller in size.
I've had one that went from brand new to needing fresh synchros in about 18k miles..
Old Oct 20, 2015 | 05:30 PM
  #274
neverstop's Avatar
neverstop
maybe could use an adjustable clutch master cylinder to get a touch more extension? no idea if that over extends the mantic clutches but my buddies stock 08 tr6060 is pretty dang smooth.
i have the MGW shifter as well, while it's a work of machined art, it did not improve the shift speed or quality nearly as much as i had hoped. i'm also considering putting stock z06 back in there
  #275
Dude_man's Avatar
Dude_man
Same shifter. I was thinking about trying the Hinson as well. I've never been a fan of aftermarket shifters though. If you get one post up your thoughts on it. It'll be nice hearing real world results from someone that's tried stock and mgw.
Old Oct 20, 2015 | 05:57 PM
  #276
Unreal's Avatar
Unreal
I have a tick master, and it has plenty of throw.
Old Oct 23, 2015 | 01:40 PM
  #277
Unreal's Avatar
Unreal
After driving it a week, I'll 100% say the t56 drove/shifted better. This is super notchy and even grinds a little until it warms up.
To Car updates
Old Oct 23, 2015 | 04:18 PM
  #278
schpenxel's Avatar
schpenxel
St. Jude Donor '15
That sucks. Live and learn I suppose.
Old Oct 23, 2015 | 06:51 PM
  #279
Unreal's Avatar
Unreal
It isn't bad, just my OEM tranny was better. Ohh well.
Spent all day tuning and running errands. AFR still just peg 10.0 on gauge but feeling better and better. Zero issues. Swapped tranny fluid, aligned the front end, and retightened exhaust/etc..
Old Oct 23, 2015 | 07:52 PM
  #280
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Why so rich? Working on SD tune now?
