C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Bye Bye LSX 434 !!!
Old Oct 6, 2015 | 12:41 PM
  #41
croatbob's Avatar
croatbob
You would need to re-sleeve the block to bring it back to 427 and then you need new slugs. 434 is a 427 30 over
Old Oct 6, 2015 | 04:42 PM
  #42
usmcpony's Avatar
usmcpony
That's unfortunate. When I bought my ECS built car with 2000 miles. It ran perfectly on the 15 minute test drive. Signed the paper work and started to drive it home. On the way home the transmission started shifting on its own even in manual mode. After getting the run around from the dealership I decided to fix it myself. Thus making it my car rather than a car someone else built. Ive since then switch superchargers and about to start a motor build. It sucks but you get more attached to your car when you put alot of work into it versus already buying it built from someone else's hands.
Old Oct 26, 2015 | 02:22 PM
  #43
Tino587's Avatar
Tino587
Pictures of what I found.
Old Oct 26, 2015 | 02:42 PM
  #44
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Any idea what happened? Those bearings look lovely!
Old Oct 26, 2015 | 05:20 PM
  #45
Tino587's Avatar
Tino587
In all honesty, I am not too sure on what could cause premature bearing failure. Maybe a seasoned veteran can chime in on what may have caused that.
My only guess is loose tolerances in order to accommodate a boost happy motor? It did make it through 16000 miles of whatever abuse it was put through at that power level.
Old Oct 26, 2015 | 05:41 PM
  #46
croatbob's Avatar
croatbob
My guess is a rough life, poor oil or too long between changes or bearing clearance at build. If it's just bearings I'd be stoked!
Old Oct 26, 2015 | 07:26 PM
  #47
Tino587's Avatar
Tino587
Being that they were main bearings, my mechanic pretty much said the block is scrap but we will figure that out here in a little bit when the rest of the block is disassembled.
Here's my next question to you guys. For some damn reason, we cannot seem to separate the heads from the block. We went even down to the last little stud and we cannot separate them on either side. We have tried several different methods:
- Pry bar wedged against bolt threaded into head casting.
- Metal Bar down intake runner and attempted pry.
- Chisel and mallet on bottom of MLS head gaskets.
Either side is not budging.
Old Oct 26, 2015 | 08:21 PM
  #48
schpenxel's Avatar
schpenxel
St. Jude Donor '15
That's weird as hell. Could always put bolt a cherry picker on to the head somewhere and pull up on it. Can chain block to leg of cherry picker to stop it from going anywhere.
I had to do something similar once when tightening a BMW crank bolt to a torque that would make the LS one look like a joke
Old Oct 26, 2015 | 08:22 PM
  #49
douniasg's Avatar
douniasg
if they are 6 bolt heads you need to remove the valley cover to get to the bolts. Is the block for sale?
Old Oct 26, 2015 | 08:26 PM
  #50
schpenxel's Avatar
schpenxel
St. Jude Donor '15
That too.
Old Oct 27, 2015 | 09:10 AM
  #51
Unreal's Avatar
Unreal
Yah, did you remove the nuts from the valley cover bolts that go down. There is studs that thread into the head and go down into the valley plate. That is the "6th" bolt. If you engine builder didn't know or can't figure that out, I would be running to a new place.
Old Oct 27, 2015 | 09:48 AM
  #52
Tino587's Avatar
Tino587
Got it thanks!!! The person helping me work on it currently is not my engine builder. He is a retired master technician from GM. He is used to older technology but the gentleman knows his stuff inside and out, that was the only snag we ran into the entire time. Having never seen my car before, we still managed to remove the entire engine in 4 hours. Credit given where credit is due. He was the one to stop the project when he couldn't figure out why. At the end of the day the last thing we removed was the valley cover, but did not think that there would be a bolt in there holding us back. Thank you for the insight.
Old Oct 27, 2015 | 10:26 AM
  #53
Tino587's Avatar
Tino587
I will assess damages and cost of rebuild and go from there. If it seems more convenient for me not to salvage this and that and machine this and that and regrind this and that then the block ultimately will be for sale.
Based off my needs for a boosted reliable engine, punching the motor out even more seems to be a no as a general consensus. I will keep you updated shortly on this.
Old Nov 2, 2015 | 07:39 PM
  #54
Tino587's Avatar
Tino587
Just found this as well.... This is where it gets really confusing for me... How in the world could I have babied the car for 1000 miles and this happens. I may have heard some of the previous versions of this callies crank had issues.
Anyone that can chime in would be greatly appreciated.
Old Nov 2, 2015 | 07:46 PM
  #55
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Holy crap!
Old Nov 3, 2015 | 01:22 AM
  #56
Tino587's Avatar
Tino587
The rest of the crank looked good.
Old Nov 3, 2015 | 02:12 AM
  #57
usmcpony's Avatar
usmcpony
There's a lsx 427ci block for $2800 brand new on the turbo bullet fb page.
To Bye Bye LSX 434 !!!
Old Nov 3, 2015 | 02:10 PM
  #58
Homeboy77's Avatar
Homeboy77
I considered this car because it looked and sounded amazing. My wife talked me out of it because it is red and she knows I want black. I hope you get to build an awesome motor and bring it back to life. Sorry for the loss though.
Old Nov 3, 2015 | 03:34 PM
  #59
croatbob's Avatar
croatbob
Main caps must have been the only think holding that engine together. Lucky it didn't destroy everything.
Old Nov 3, 2015 | 03:36 PM
  #60
croatbob's Avatar
croatbob
Yeah I almost pulled the trigger on it too the first time I went 4 sale.
