Bye Bye LSX 434 !!!
. Back in March this year I traveled down to Florida to purchase a 2007 Victory Red Z06 with a Dallas Performance 5R package and an F1R procharger. At the current time it was a fantastic price for this car and setup and it laid down 1001WHP/890TQ. It was documented to have been built at 21,XXX miles, and I picked it up with 35,XXX miles. None the less, quite some mileage for a 1000HP build, but I had tons of faith in the LSX as my Subaru WRX was sold with a built motor at 500whp and 16,000 HARD miles on it still rolling strong to this day.When I got the car back to Michigan I realized there was an intermittent problem with boost and hesitation. At first I thought spark plugs and wires, or really anything ignition related. Come to find out there was a gaping hole in the Procharger intercooler causing massive boost leaks and horrible drivability.
Problem 1 solved, took it out had it welded by a good buddy and off we went to making good power again
. Problem 2, I noticed since day 1 of owning the car. Oil pressure problems. Would see at the lowest 10psi at an idle on a hot hot day. Texted the seller of the vehicle and contacted Dallas Performance. The seller said he has noticed that the entire time he has owned the vehicle it was like that and that it seemed normal due to huge clearances in the built motor. Sounded believable but also questionable. Taylor at Dallas Performance tells me its not a direct indication of a problem, and to try 20w-50 oil.
A week later I switch over to Brad Penn 20w-50. Same issue, oil temp rises to temp and the pressure drops to 10psi. I think nothing of this at this point as the car ran strong and I strongly believed in the rule of thumb "10psi per 1000 RPM".
Forward to 6 months later and only 900 miles of easy driving and only a FEW pulls literally, I am merging on the highway one morning on my way to work and I accelerate up to speed like any normal human being would decide to do so. Gets up to 3,000 RPM and next thing you know a clusterbomb of noises starts coming from the engine bay. I pull over immediately as the car coasts to a stop. I attempt to fire up the engine one more time in disbelief and turn it off right away as I hear the same noises. A tow truck later and a sad visit back to the house, I believe I may have spun a bearing.
End of rant. Thankfully I live in a state where the Winter is longer than any other season and have ample time to decide what route to take with this new build.
Ideas are greatly appreciated as I am tattered and torn as to what to do now. Punch it out to a 444 and an F1X or rebuild and go E85?????? Will keep you guys posted with pictures of the tear down and rebuild. Stick around as this will be a long one!!!
Bitterness at its finest!
UPDATE: Spun the Main bearing on #4, #5 was on it's way out, the thrust was shot, and the main cap #5 had plenty of crank marks from walking into the cap. Here are pictures of what I found please forward to most recent post to see the pictures. The heads seem to be fine at this point. So I will be replacing the shortblock with a new LSX iron block w/ billet rotating assembly. No point in attempting to salvage this block. Plus it seems like this is an excuse for me to go back to a 427 C.I.
More Updates: Just found out the crankshaft snapped clean right by the journal.....
I have been following BadBowtieProductions F1X 444 C.I. Build. It seems to be a very awesome build and at this point, it might be safe to "assume" I will need to punch out the block in order to accommodate new internals. It would be great to know that I could reuse most of the internal components in the bottom end, but that typically is asking for too much.
Thanks for the support and reply. I am new to this CorvetteForum and a proud new owner, regardless of the situation I am in haha.
lot of labor to pull the motor but if just a spun bearing I'd just rebuild it and if you have the fuel system move to e85. sucks but at least you can really make the car your own now and good change to make some upgrades while you're in there
Thanks for the motivation and your own sad story. Sometimes it takes knowing that this has occurred to others as well to keep me moving forward.
Thanks for chiming in, the support you guys give is above and beyond, and now I know why I left the Subaru scene
I'll stick with the south!
I wouldn't go nuts on the cubes.
I'm gonna be moving back to Michigan in the next few months. Hopefully when yours is completed we can get some cruising in when the weather clears. Good luck with everything.
but you might need a bigger fuel system... better clutch... and more *****
lemme clarify.. My 434/f1r combo made an identical 930 rwhp to your car.. for them to make 1000 rwhp.. i bet its spun to the moon and out of steam by 6000 rpm.
i went to a 427/f1x and made 1460.
I hear you on the road conditions. I lived in St. Joseph MI when I was young. Still love the area and try to get up there on occasion.
-Miles
