C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Spark plug replacement on boosted engine
Old Oct 6, 2015 | 10:53 PM
Pitufina's Avatar
Pitufina
Default Spark plug replacement on boosted engine
How often do you replace the spark plugs on your boosted ride? I use the ac delco 41-104 iridium (z06, zr1) oem plug gapped .032. The ones currently on the car are around 10 months old.
Old Oct 6, 2015 | 11:00 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Mine were still like new after 2 seasons and about 5000 miles. I changed them anyways when changing blowers since I wanted everything to be new from that point.
I don't use iridium though so cant speak for those.
I will check these at the end of each season and change when needed.
Old Oct 6, 2015 | 11:11 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
My tuner recommended every other oil change (6k miles)
Old Oct 6, 2015 | 11:13 PM
Pitufina's Avatar
Pitufina
I don't know how many miles but probably more than what you have. I know iridiums are supposed to last longer than the copper ones but I feel that forced induction shortens the lifespan on them too. My question is how can you tell when the iridium spark plugs are failing? The fuel economy on my vette is getting bad and I feel a slight hiccup while cruising. Idle feels a little rougher too.
Old Oct 6, 2015 | 11:38 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Every other oil change is way, way overkill, especially on Iridiums, unless you're running rich as hell all the time (i.e. open loop and forcing it to run that rich)
I say run'em till they misfire
Old Oct 6, 2015 | 11:55 PM
Unreal's Avatar
Unreal
I think I got ~15k miles on this set.
Iridiums probably every 30k miles. About as often as the heads have to come off for a refresh.
Old Oct 7, 2015 | 07:43 AM
Pitufina's Avatar
Pitufina
I think you run the tr7ix, correct? I'm thinking that the "flooded" starts that I experienced after moving the IAT sensor to the intake and not using the zr1 data correctly put a toll on the spark plugs. I'm going to remove a couple of them sometime today or tomorrow and take a look.
Old Oct 7, 2015 | 10:36 AM
C U IN REARVEIW
I get those "flooded/large cam feel" starts often lately....is that something I should be looking into?
Old Oct 7, 2015 | 10:38 AM
Streetk14's Avatar
Streetk14
Maybe I missed it, but did changing to the ZR1 IAT2 data and axis labels fix your startup issues?
Either way, I can't really see that permanently damaging the plugs. They should clean up during normal driving. Iridium plugs should have a very long life. I think a stock ZR1 is supposed to be good for 100k.
Oh, and if you're looking for plug recommendations, check out the Denso IT22. They're a "7" heat range, and come pre-gapped at .032". Denso makes the OEM ZR1 plugs, so I'm thinking they'll be a good, trouble free choice. I have a set ready to throw in to replace my TR7ix's when I feel like it.
Old Oct 7, 2015 | 12:43 PM
Unreal's Avatar
Unreal
8ix
Old Oct 7, 2015 | 01:01 PM
Pitufina's Avatar
Pitufina
If you are experiencing flooded starts I'll say that the tune should be revised.
Yes, changing to the zr1 parameters fixed my issues. I'm going to take a look but you may be right.
8ix
Thx
Old Oct 8, 2015 | 08:58 AM
Streetk14's Avatar
Streetk14
Thx
That's good. I didn't know if it would, but I know I didn't like the readings I saw before changing mine.
I have yet to try the Denso plugs, but a bunch of guys swear by them. I figure they're as close to a "7" range OEM plug as you can get. A bunch of people have issues with NGKs causing charging warnings, plus they come gapped at .040". Since gapping iridium plugs is a little dicey, the IT22 coming at .032" is a nice touch.
Old Oct 8, 2015 | 09:30 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Think I'm going to give the Denso's a shot next time I change plugs. I'm running the ZR1 ones now.
Old Oct 8, 2015 | 12:06 PM
07blkvette's Avatar
07blkvette
what type plugs is everyone using?what gap also?
Old Oct 8, 2015 | 12:07 PM
Pitufina's Avatar
Pitufina
I don't know if I should start another thread but I guess I was too fast to call the IAT sensor changes in the ECM successful. Yesterday afternoon and today twice the same symptoms reappeared! This time it takes a while to start and I have to actually press the gas pedal some. I'm pissed at this point!
This always happens after engine has been brought to operating temps, shut if off and try to restart half hour later or so. It starts perfectly every time when cold. Another thing I noticed is that it runs somewhat rough idling and cruising until the temps reach 180 or so.
Any suggestions other than relocating the iat sensor to the charge pipe right after the maf?
Old Oct 8, 2015 | 12:23 PM
Detoxx03's Avatar
Detoxx03
I run 8ix's
Old Oct 8, 2015 | 12:27 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Zr1 plugs here. 41-104 I think is the number.
Wish I had a suggestion on how to fix that issue. Have you talked to Dave about it? Figured he might have some ideas
To Spark plug replacement on boosted engine
Old Oct 8, 2015 | 12:46 PM
Pitufina's Avatar
Pitufina
No, I haven't. I don't want to bother him too much. I think that I'm just going to move the sensor to the charge pipe behind the maf.
Old Oct 8, 2015 | 12:53 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yeah, that seems like the logical next step. Will be interesting to see if that fixes it or not
Old Oct 8, 2015 | 01:20 PM
Streetk14's Avatar
Streetk14
I already told you what I think it is. I really doubt moving the sensor 4 inches forward is going to change much, but that's just my opinion.
