Nitrous Dry kit users in here please!
Single or dual nozzle, what brand kit?
Injectors, fuel pump or boosta pump, brand?
How are you pulling timing, tune or lnc box or both?
How much are you spraying and how much did it pickup your et/mph?
Thanks!
I've got a dry shot on my 08 Ls3 m6. Found a good deal on the forums and figured I'd have some fun with it until I get around to building my turbo kit. I've got mine setup very similar to this thread from spinmonster here: https://www.corvetteforum.com/forums...wet-shots.html
Single or dual nozzle, what brand kit? Dual nozzle HSW kit
Injectors, fuel pump or boosta pump, brand? Stock injectors and fuel pump, The stock injectors look to be about maxed out on 100 shot that I'm running now.
How are you pulling timing, tune or lnc box or both? Using IAT tricker circuit to pull timing in tune and add fuel
How much are you spraying and how much did it pickup your et/mph? Spraying 100 shot right now but Havn't been to the track yet so not really sure, need to get some good tires first.
Thanks!
I'm Probably gonna go ahead and put the 150 jets in there and see what injector duty cycle is, I've got a boostapump so I may throw that on and see if that will keep the IDC down enough.
