C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E85 questions
Old Nov 10, 2015 | 09:48 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by schpenxel
BMW also has wideband O2 sensors to adjust WOT fueling on the fly. GM does not.
Yes, BMW has electronic waste gates.. GM computers don't even have a way of controlling waste gates, much less making adjustments based on ethanol content.
Like I said.. BMW are far more advanced.
Actually GM does control waste gates electronically and they can make adjustments based on ethanol content once the sensor is added and turned on in the ECM. Same as any flex fuel car from the factory.
The new V6 turbo's, Buick Regals and Caddy's too can increase boost via the ECM. I have tuned a handful of them.
I call those "hero tunes" because it's so easy to look like a hero.. A couple of computer strokes and you can increase boost by 3-5lbs in the mid range. They still run out up top though so it's mainly a TQ increase , but it's an easy 40-45 ft lbs and 20-25 HP.
They do need to add a WOT wide band though, that would be great.
Old Nov 10, 2015 | 10:04 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I didn't say they didn't have an ethanol input... I'm very familiar with that and am using it now with some custom stuff I've built (though not for E85 directly). I can vary ignition timing (and AFR if I wanted to) based on methanol system pressure.
I didn't know they had electronic control of waste gates.. that's pretty cool. Must be for some of the little 4 cylinder turbo'd cars or something?
Old Nov 10, 2015 | 10:23 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Yeah I forget what computer it used in those, but it's a nice feature. EFI live an HP can access them though. I have only tuned 6 cylinder turbo applications with it.
Sorry I misunderstood you on the Ethanol.
Old Nov 10, 2015 | 10:36 AM
1MEANGS's Avatar
1MEANGS
Originally Posted by DOUG @ ECS
Our E85 fuel system is $1,299, add the sensor and injectors if needed with your originals sold to offset, and it's still going to be less then the very bottom of your range there.
I do like the availability of increasing timing etc all on it's own, but you're right with just adding meth being far less expensive.
What fuel system of yours is rated for e85... The stage 2?
Old Nov 10, 2015 | 10:52 AM
miwitte's Avatar
miwitte
So that makes perfect sense now. I can just dump E85 in and the WOT wideband on the BMW will compensate. In the Vette it uses a table lookup at WOT that's why you have to tune for E85. Is that why some high power turbo guys use different ECU's?
From a Meth standpoint what are you tuning? My understanding its used to increase octane and cool the IAT. From a tune aspect does the tuner add more timing? or more fuel as well?
Old Nov 10, 2015 | 10:56 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Basically, yes. Widebands can read AFR anywhere from like 7:1 to 20:1 (depends on model, but you get the idea). Narrowbands, which is what GM uses, can really only say whether you're learner than 14.7:1 or richer than 14.7:1. There's no real resolution beyond that. That works fine for cruising down the interstate, but at WOT you'd want richer than that obviously, and the GM sensors are useless in that regard.
Yes.. integrated widebands are a nice feature on aftermarket ECM's
There are different ways of doing it. A lot of people spray meth on or near the IAT sensor, so they add timing only if the IAT gets cold enough to be sure meth is spraying. Some people also lean things out a little bit since meth is a fuel and will make things go richer (all things being equal)
Some don't.. some just spray a small amount of meth on top without changing a thing. Different strokes.. etc.
