C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E85 ID1000s
Old Dec 16, 2015 | 04:37 PM
Dude_man's Avatar
Dude_man
Default E85 ID1000s
Whats the highest hp youve made before maxing them out on e85? What was your base fuel pressure, how much boost, etc?
Ive heard of people making 1000WHP but I just find it hard to believe
Old Dec 16, 2015 | 04:41 PM
C6 Curtis's Avatar
C6 Curtis
I have ID 1000 at 60psi base pressure, I believe it's around 84-86% IDC @ 840whp on E85 I'm only on 5.8psi though with a boost 1:1 regulator so it only bumps mine up a little. If you are running more boost you will get more out of it.
-Curtis
Old Dec 16, 2015 | 04:47 PM
Dude_man's Avatar
Dude_man
-Curtis
Im swapping out my 044 for a DW350 tomorrow. Im hoping thats my issue. My IDC has broke 100% and I know Im not making more than 850.
Old Dec 16, 2015 | 04:53 PM
C6 Curtis's Avatar
C6 Curtis
What injectors are you using? Yea I'm running a Grams 440lph pump it's a 044 direct swap. I had to replace one of my aem380lph with it.
-Curtis
Old Dec 16, 2015 | 04:57 PM
Dude_man's Avatar
Dude_man
-Curtis
Id1000s, I have a walbro 450 intank then the inline
C6 Curtis's Avatar
C6 Curtis
http://store.gramsperformance.com/fu...fuel-pump.html
You don't have your 450 feeding the 044 right?
Old Dec 16, 2015 | 05:06 PM
Dude_man's Avatar
Dude_man
No they run parallel
Old Dec 16, 2015 | 09:00 PM
Mike Farris's Avatar
Mike Farris
Are you guys running these through the stock lines like ecs does or running them both into something like a -8. I guess you could use stock lines for the intank and a -8 for the external also.
I'm thinking about running a z06 pump through stock feed line and a grams440 through -8 and bring them together just before the stock fuel rails. Use the Schrader valve to feed a regulator and -6 return line. Boost referenced with blockoffs in both tanks. Reasonable?
Old Dec 16, 2015 | 09:15 PM
Dude_man's Avatar
Dude_man
That's exactly how mine is
Old Dec 16, 2015 | 11:14 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
That's good. Mine is same way.
Old Dec 16, 2015 | 11:19 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I've always been told to take it easy in terms of weight you put on the Schrader valve. Just a heads up. Never seen one leak but they don't look all that strong either.
Old Dec 17, 2015 | 09:07 AM
Dude_man's Avatar
Dude_man
I wouldnt recommend mounting a regulator directly on it.
Old Dec 17, 2015 | 09:13 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Old Dec 17, 2015 | 10:10 AM
C6 Curtis's Avatar
C6 Curtis
I'm running 2 -8 feeds that merge into a -10 and -8 on the return side.
-Curtis
To E85 ID1000s
