Ls2 head gaskets
Jan 29, 2016 | 07:52 PM
Ls2 head gaskets
Wen should I be worried about my stock ls2 head gaskets this is a f/I car
Jan 29, 2016 | 09:19 PM
Jan 29, 2016 | 09:24 PM
St. Jude Donor '15
Jan 29, 2016 | 09:34 PM
Jan 29, 2016 | 10:09 PM
Jan 29, 2016 | 11:39 PM
St. Jude Donor '15
The specificity is overwhelming
Jan 30, 2016 | 08:01 AM
Lol.just wasn't sure if I had to much boost on the oem gaskets n bolts
Jan 30, 2016 | 05:24 PM
St. Jude Donor '15
How much boost are you running?
Knock will cause some serious cylinder pressure spikes and kill gaskets (or pistons). So, avoid knock/too much timing and that will help a lot.
Jan 30, 2016 | 06:01 PM
13.5 after my ethanol tune is finished it will prob be 14 or so
Jan 30, 2016 | 06:03 PM
St. Jude Donor '15
Jan 30, 2016 | 07:00 PM
Flex fuel car. I prefer to only ethanol anyway
Jan 30, 2016 | 07:31 PM
St. Jude Donor '15
Yeah the flex fuel setups are really nice. Been thinking about doing it on mine but I've got a setup I built that is using the ECM's flex fuel input to change timing based on methanol system pressure, so I'd have to ditch that if I went to a "regular" flex fuel setup. Kind of a "failsafe" instead of trying to use the IAT as one
Jan 30, 2016 | 09:02 PM
Yeah I did my own flex fuel setup .e85 is alot better then meth I'd say
Jan 30, 2016 | 09:57 PM
St. Jude Donor '13
If the engine is stock the pistons will probably go before the gaskets will.
Jan 30, 2016 | 10:53 PM
