C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost Controllers
Old Feb 20, 2016 | 01:18 PM
BRING IT's Avatar
BRING IT
Default Boost Controllers
What is everybody using on their turbo setups?
Old Feb 20, 2016 | 02:37 PM
C6 Curtis's Avatar
C6 Curtis
I have an aem tru boost
Old Feb 20, 2016 | 04:09 PM
BRING IT's Avatar
BRING IT
I looked at those too. I think I want one that has a square display.
Old Feb 21, 2016 | 05:44 AM
Unreal's Avatar
Unreal
Gfb
Old Feb 21, 2016 | 11:36 AM
BRING IT's Avatar
BRING IT
Originally Posted by Unreal
Gfb
I like the look of that one. What are you using for AFR and fuel pressure? I have a Dashlogic module which I think you can be used.
Old Feb 21, 2016 | 02:36 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I'm using dash logic for wideband and fuel pressure. Works great.
Old Feb 21, 2016 | 04:03 PM
BRING IT's Avatar
BRING IT
What else do you have to buy? Also how long does it take to install?
Old Feb 21, 2016 | 06:44 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You need a pressure sensor and a wideband sensor+controller. Wiring isn't too bad.
The fuel pressure sensor has three wires. One connects to 5V+ (there's a wire on the MAP sensor you can use), one connects to ground and the other connects to dash logic
For the wideband you have to install an additional O2 sensor then run the wire for the sensor back to a controller. The controller will need 12V and ground, and will have an output wire (0-5V) that connects to the input on dash logic.
Then you have to configure dash logic to know what to do with the signals it is now getting
Not hard by any means but takes some time to do it neatly.
I'm using a PLX gen 4 4.9 wideband and for pressure sensor Honeywell's PX2AF1XX150PSAAX should work. It has a female schraeder connection so it will screw on to the end of the fuel rail.
To Boost Controllers
