Heartbeat arrived!
So, I guess the only plan I have now is to finish the charger install, without pinning the crank, try to get into a shop for the dyno, and pay them to pin it. What a load of crap.
Anyone have any words of wisdom? All of my words might get me kicked off the forum.
The first time I used a 3/4" drive breaker bar that was 2' long and put a 6' piece of black iron pipe on that and it still took everything I had to get it to go.
Second time I had a strong enough impact wrench to get it off (though having been off once probably helped)
These crank bolts are tight, but I think the tightest I've ever seen was on a BMW V8 engine. I literally was in the air, hanging on the end of 6 feet of pipe when trying to loosen the crank bolt on that thing. I'm not that heavy so I guess that didn't help me there. It sounded like a gun shot when it finally broke loose
I hope yours takes less than that!
http://www.summitracing.com/int/part...0326/overview/
I think I'll go rent a badazz compressor tomorrow, and see if the impact I bought can get it. My compressor is a bit weak for the impact.
IIRC, it took me about 2-3 hours of heating with a MAP torch, cursing, and beating on and off at that goddam bolt with a 1/2" air impact before, all of a sudden, it started to move.
You are right a that with air impacts, you have to make sure you have the CFM the impact needs for it to work properly. And make sure that the compressor pressure is fully pumped up before using the impact and keep beating in it as long as you can and then stop and let the compressor charge up again and heat it while you wait for that. I've had the experience working on heavy machinery with a 3/4" impact that just something like changing the size of the hose makes a world of difference.
If that doesn't work, pull the rubber plug on the backside of the bellhousing and jam a prybar into the converter mounting lug and then use a breaker bar with a pipe extension over the handle to break the HB bolt that way. Good luck with that, it's a sumbitch for sure.
Then, of course, you have to tighten it again too, when you're done!
Once you have the bolt pulled, be prepared to spend a bit of time drilling on that crank too. That ba$tard is hard too!
Just make sure that you have the engine high enough off the cradle so that the steering rack is out of your way.
You've got a few more hours of cursing, I'm afraid, but after that it should get better!
Good luck. I feel your pain, my brother!
But if it screws around with me, I've got a 2200 ft.lb. torque multiplier that my guys use on my machinery. That'll sort it out real quick.
I bought it from Northern Tool (link below). Works real good. Just make sure that you anchor the multiplier handle securely on something that won't break off, before you put force on the ratchet handle, because that's going to see 3 times the force you exert on the ratchet handle. I've used a pipe on a 3/4" breaker bar with this thing on one occasion and it didn't break (but it did twist off the 1 1/2" grade 8 bolts that we were trying to remove easily). One of my guys insisted on holding on to the multiplier handle and when I pulled on the pipe, it lifted him clean off the ground. Sometimes there's nothing like demonstration to drive a point home.
http://www.northerntool.com/shop/too...3947_200623947
Started calling around for a compressor to rent, could not find one better than mine that didn't have to have a trailer anywhere close by.
Went back out, Glared at the bolt, grabbed the propane torch, heated the bitch up again, hit it with the air impact again, and off it came.......What a chump azz piece o'crap.
So a whole day wasted on one silly bolt. Making some good progress now, hitting the coil packs next.
I'm wondering why "that guy" above with all of those heavy duty tools hasn't pulled his balancer and installed the new cam yet??!!
He prob dreading tackling that damn bolt, and I don't blame him!
could have designed an angled back a bit and allowed bolting from the top, but no. How the hell did you get those bolts in and tightened. Guess I'll see if I can drop a bit more on the subframe, my hands are not small....
