New TTIX build and questions
The C6 instructions have you tap the riser that the oil pressure sensor mounts to in the valley cover. The line lengths are based on that.
Ok then i have to check my length of the feed lines.
I have got some parts now for some uppdates
Fore innovations dual 450 walbro pump
3" TTiX downpipe
Clutch
Building my own 2.5 map sensor
I also got but i dont have any pics of it
Grandsport kit
Forgline SP3P 3 piece
2006 Steering wheel
Cardstyle maf
z06 muffler with muffler mod
Bilstine DRM shocks
New seat covers
A rolle of 3M Matte blue wrap
3" TTiX downpipe
Clutch
Grandsport kit
2006 Steering wheel
Cardstyle maf
Bilstine DRM shocks
New seat covers
Received 1,194 Likes
St. Jude Donor '15
Those 2.5 bar map sensors are a joy to build
That Fore hanger wont drop in assembled. You'll only be able to drop one in with the hat. The other two have to be put in one by one in the tank.
Also, the check valve can just be threaded right into the external fuel filter.
St. Jude Donor '15
ZR1 MAP won't work on a 2005/E40.
St. Jude Donor '15
lol, that's what she said?
Burn
Burn
The car i now wrapped, and im going to start whit the fun pats.
im going to change the motor mount when im intalling the ttix kit but does like the Delrin mounts work or is it going to be to hot with the turbos?
Like the wrap color. Mind telling me about how much you paid to have it done? Places by me want about $800-$1000 which seems high.
Either case, definitely would look killer with some black wheels though
Holy crap that is cheap for a wrap. Places here are all $2500-3000.
#34
I have been collecting some parts and so far.
3" dp from Champion Motors
ID2000 injectors
Dewitts radiator
Card style maf and 2.5 bar map sensor for e40
Z06 exhaust that i did the muffler mod to.
But does some one have the ttix manual for c6? I dont know if it says anything in that but does somebody know if i have to modify the ac pump/lines on a 2005? I did read some where that a few had to do this?
And does any one have a template for how mutch i need to trim the motor mount? It seams like its a pita to do it whit the engien in the car...
ID2000 injectors
Dewitts radiator
#35
2000s are zero issue if you have a 1/2 way competent tuner.
That being said I wouldn't run them with ethanol. Would rather use a full ethanol compatible injector.
#36
The ID1700 are ethanol compatible according to their techs when I called before ordering.
#37
St. Jude Donor '15
ID1700's are fine for ethanol
Also, everyone has the best tuner
#38
Yes the 1700x are fully ethanol compatible. The ID2000s are not.
Your tuner can't be better than me, because I'm the best.
#39
You're going to really like the TTI X kit. I sure have fun with mine
