Best Cam for Boost ... Please Help
If you're there to pin the crank anyway, and you don't want a big rumpy cam, the LS9 cam isn't a bad way to go. LS2,3,6,9 springs are the same. As long as your plans don't include big boost and spinning that thing to the moon, your stock LS2 springs are good with the LS9 cam.
yes... I got this much from the post here.... my brother contacted LIL John today to see what we will end up going with.... best cam setup for my car
Yes, labor to swap just the cam is the same. LS9 cam can be had for +/- $125. Custom cam will cost $400-500. A hundred + for pushrods, 250 to 300 for springs, and quite a bit of labor to swap springs. None of that needed for an LS9 cam. For someone wanting a mild cam and a mild parts and labor bill, the LS9 cam isn't a bad way to go.
I am still of the opinion that if you are going to do it do it right or just save the bills altogether and keep the stock cam.
But how "custom" that would be for a stock LS2?
In other words: if your build is "custom", then get a custom cam.
If you have a stock LS2, then, well...
If it were me, I would get a custom cam ground for a stock LS2 motor (yes, I do understand what that means - i.e. a stock compression, 6.0 liter with stock cathedral port heads) with some extra exhaust timing and a wider LSA for boost, and change the springs to some PAC beehives and install better pushrods. That would involve just a bit more labour, so it shouldn't break the bank just to change valve springs.
As far as cam specs go, if you want to keep it quiet without too big of an impact on mileage, just tell your cam guy that you want a lobe with a mild ramp, and keep the intake duration at 0.050" less than 218* with about another 10* on the exhaust and an LSA of 116+*.
Also, bear in mind that the LS9 cam was designed for the rectangular port heads, which tend to need a much wider intake/exhaust duration split than the cathedral port heads, which I why I would personally go with a custom grind for cathedral port heads, although I don't know if that makes a world of a difference.
Just my 2 cents, FWIW...
Also, bear in mind that the LS9 cam was designed for the rectangular port heads, which tend to need a much wider intake/exhaust duration split than the cathedral port heads, which I why I round personally go with a custom grind for cathedral port heads, although I don't know if that makes a world of a difference.
Thanks for all the great info it sounds like that's exactly what I'm going to do is get a custom grind
AES 399" Forged & Stroked LS3 with an A&A V2 Ti.
I am now looking into a cam more tailored for my set up.
Wish I would have done that to being with!!
Add two tuner gurus into the picture as well.
You'd probably get two different results even with the same cam...
In other words, it's the combination of mechanical/electrical components and the tune.
With two different tuners but with exactly the same engine/cam, the other car might be undrivable on the street but the other one being just fine.
The best cam for your car depends both the cam guru and the tuner guru. :-)
