C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fuel pressure question
Old Apr 6, 2016 | 01:35 AM
c6 monkey's Avatar
c6 monkey
Default Fuel pressure question
I have 2006 base model ECS1500 ECS fuel pressure booster. Ive had the blower in my car for a week. Today I noticed while in boost it's underpowered, last Friday I could spin the tires at 60 mph, not today. Fuel pressure was at 60 psi but today it's at 58 then in boost it drops to 54 or so. I'm wondering if it's starving for gas or if it's a tuning thing, or maybe a bad fuel booster. Any toughts?
Old Apr 6, 2016 | 10:17 AM
Dude_man's Avatar
Dude_man
Assuming this this is a non return style fuel system. Thats pretty normal that it drops a little. Do you have a wideband? If so whats the afr?
Old Apr 6, 2016 | 12:16 PM
c6 monkey's Avatar
c6 monkey
Default It's a stock fuel system for the car ..LS2
I don't have a wideband. I have a dual guage pod with boost and fuel pressure guages. I called ECS Cris said it's probably not a fuel pressure problem. It's supposed to drop a little. He said if it went down to 40 psi that would be a thing but going to only 54 or so should be ok. He said belt slip or tune. I'll call the tuner and have him look at it again. Do tunes have to be touched up sometimes as things adjust and break in? Do you think I should ditch one of my guages and get a wideband?
Old Apr 6, 2016 | 12:22 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Wideband is more important than either of the two you have, IMO
Old Apr 6, 2016 | 12:42 PM
neverstop's Avatar
neverstop
certainly get a wideband
Old Apr 6, 2016 | 02:39 PM
c6 monkey's Avatar
c6 monkey
Default Got it
Thanks guys, which wideband is best, and to ask again do tunes have to be touched up as things break in? It was tuned last Thursday for the first time
Old Apr 6, 2016 | 02:42 PM
Dude_man's Avatar
Dude_man
I like the Plx, and no they shouldn't
Old Apr 6, 2016 | 04:58 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Have had good luck with PLX as well. AEM is supposed to have a new one out that is faster but I haven't gotten one yet to try it out.
Old Apr 13, 2016 | 08:56 AM
Daniel@Vengeance's Avatar
0Daniel@Vengeance
Former Vendor
Another good option for a wideband is the Innovate LC-2.
Old Apr 13, 2016 | 10:19 AM
telly444's Avatar
telly444
my 200 dollar wide band and fuel pressure gauge saved me 10k when my fuel pump went and car was going lean. its a must have. any one will work. AEM, autometer. innovate.....
Old Apr 14, 2016 | 12:41 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
AEM has a Boost/WBO2 in one gauge that works great.
30-4900
Old Apr 14, 2016 | 01:34 PM
Unreal's Avatar
Unreal
Just finished putting the aem WB/Boost fail safe in, and i like it. Works great, and easy to setup warnings.
I also use dashlogic, but haven't got around to doing an apillar and won the AEM in a dyno contest so had it laying around.
To Fuel pressure question
