C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E85 dyno results
Old Apr 11, 2016 | 04:27 PM
slowls3's Avatar
slowls3
Default E85 dyno results
Car is a 2009 automatic with 3600 stall, ECS1500, g6x3 cam, full exhaust, etc..
Now has A&A dual pump system, Id1300s and dsx flex fuel sensor. Restrictor plate still in place on supercharger.
Previously on 93 octane made 623/542
Now on E85 makes 685/595
Really happy with the numbers and can't wait to pick it up this Friday and drive it.
Old Apr 11, 2016 | 05:11 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
Original tune was 93 octane only? Good numbers for comparison.
Any idea on total timing advance at WOT between both tunes?
Old Apr 11, 2016 | 05:19 PM
bdickey058's Avatar
bdickey058
I went from 612 on 91 without meth to 747 on e85! Nice numbers. Have fun
Old Apr 11, 2016 | 05:31 PM
slowls3's Avatar
slowls3
Yes 93 only. I do not know about the timing but can check with my tuner.
Old Apr 11, 2016 | 06:45 PM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Thanks for posting. I've always wondered what kind of difference it would be going from 93 to E85. From the numbers it looks nice, but not sure it's worth the cost of upgrading the fuel system for me since I already have meth set up.
Old Apr 11, 2016 | 08:17 PM
xBoostx's Avatar
xBoostx
Hey man congrats solid gains glad you try it is one biliever at a time lots speaking against it however you will know who tried it by what his saying there's plenty more venefits as well to be enjoyed, smell good engine runs cooler cylinders chambers spark plugs exhaust all will clean out and run way cleaner but power is still top bonus, enjoy...
Old Apr 11, 2016 | 09:22 PM
Detoxx03's Avatar
Detoxx03
Awesomesauce. I love the stuff. Flex fuel is one of the best mods I've done.
Old Apr 13, 2016 | 08:48 AM
Daniel@Vengeance's Avatar
0Daniel@Vengeance
Former Vendor
Great results for just the fuel change!!
Old Apr 15, 2016 | 09:12 AM
Nosferatu's Avatar
Nosferatu
St. Jude Donor '14
I'd be more curious of 93 + meth vs E85. I run E85 on my daily driver
Old Apr 15, 2016 | 10:03 AM
EvanZR1's Avatar
EvanZR1
Would love to see a comparison of the two options. I'll even volunteer my car as a test platform if anyone wants to help fund the fuel system upgrade.
Old Apr 15, 2016 | 10:28 AM
Nosferatu's Avatar
Nosferatu
St. Jude Donor '14
Exactly. It's a no-brainer E85 > 93. I used to run 93 with and without meth on my C6. Going from 93 to E85 feels like the same jump on my GTR but this is obviously all just seat of the pants feeling.
Old Apr 16, 2016 | 08:56 AM
MBB's Avatar
MBB
I'm doing the flex fuel conversion myself as I really really don't want to run meth and there are 4 Kroger's in my local area that have E85. Keeping it simple with a Bosch 044 and 82lb/hr injectors from FIC (stock injectors punched out). Gonna run her unrestricted and see what she makes, I'm guessing it will be +/- 700whp. I think I'm at around $500 for my setup
Evan, if you want to do the flex fuel conversion you can either buy the Flex Fuel kit from DMS ($400 but plug and play) or simply buy the sensor and build your own lines. There are instructions on where to pin the sensor into your PCM. All you need is your tuner to activate the tables and boom...you can fill up at either pump and the ecu will correct for octane on its own.
The GM Flex Fuel sensor part number is: 13577429
The GM Flex Fuel Sensor pigtail part number is: 13352241
Here's an awesome thread where a member made his own setup: https://www.corvetteforum.com/forums...d-results.html
Old Apr 16, 2016 | 10:31 AM
EvanZR1's Avatar
EvanZR1
Not concerned with the cost of the flex fuel setup, rather it's the cost of a fuel system upgrade. I'd have to either upgrade to a Fore system or A&A/ECS add-on system to supply enough fuel to run E85. Also, I'm just not sure E85 is going to make any more power than 93 w/ meth.
What did you do to your car? If you're guessing 700RW with E85, you must be at 600+RW now.
Old Apr 16, 2016 | 02:00 PM
MBB's Avatar
MBB
Why do you think that you need to upgrade the fuel system with a Fore dual pump system or the ECS add on for 7xxwhp? You can run a single Walbro 450 and a Bosch 044 in line and supply enough fuel to upgraded injectors.
E85 may make the same or a bit more than 93+Meth, but it's worth it to run it over meth because you won't have to worry about it running out or having a Meth system malfunction. Do the Flex Fuel conversion and never worry about getting meth again.
Old Apr 16, 2016 | 02:21 PM
Detoxx03's Avatar
Detoxx03
It will make more than 93/meth
Old Apr 16, 2016 | 05:47 PM
EvanZR1's Avatar
EvanZR1
Any way you look at it, it's still an upgrade to the fuel system plus the flex fuel setup and updated tune. And if I'm going to go through all that headache, then I might as well go full retard and do 3.4" pulley, long tubes and cam at the same time. Of course if I do all that, I'll really need something like a ProEFI for traction control as I'm already traction limited.
Thus I think I'll just leave it where it's at and enjoy it.
And there's really no worry with running meth, I pick up 5 gallons at a time and it typically lasts me 3-6 months, which is way easier than worrying about finding a station with E85.
Old Apr 16, 2016 | 07:35 PM
Zeekaral's Avatar
Zeekaral
Traction limited? I have a C6Z on a 200 shot and dead hook at a 60 roll. Have you ever heard of drag radials? Pro efi what a waste for a sub 1600rw vette.
To E85 dyno results
Old Apr 16, 2016 | 07:40 PM
MBB's Avatar
MBB
I think you're overcomplicating this in your head E. How in the heck are you traction limited at sub 7xxwhp? 7xxwhp isn't full retard, that's mid level street car power. Full retard is a little over double that.
Are you not running drag radials yet? There are people making A LOT more than you or I that are still perfectly ok on DRs running a stock ecu with HPTuners. ProEFI? For a sub 1,000whp car?
I agree, your car is overdue for LTs and a cam..but that's more for sound and fun factor. Even after cam and LTs you'll be lucky to break 750 on 93/meth and if you do you'll be working that blower hard at that point anyway.
Old Apr 16, 2016 | 10:17 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yeah, not understanding the need for ProEFI for that power level.
Old Apr 17, 2016 | 12:02 AM
Detoxx03's Avatar
Detoxx03
I wouldn't say sub 1000whp has no need for it but sub 800 definitely doesn't have a need for it.
