C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Warm Weather cooling
Old May 3, 2016 | 05:44 PM
cwylie's Avatar
cwylie
Default Warm Weather cooling
What are you all doing in the southern states for cooling on your forced induction cars? I just purchased a TT 427 car and it runs around 200 when moving but as soon as slow down or get stuck in traffic the temp goes up pretty quick. Its running a Dewitts radiator and the dual spal fans. I want to switch to the single brushless but they are out of stock until July. What water pump and thermostats are you running?
Old May 3, 2016 | 06:16 PM
nenji01's Avatar
nenji01
160 thermostat
if you can put an eletric waterpump im sure your temps will go down
also add a oil cooler for the engine and that will bring temps down aswell
does are the only things i can see that could help u out big time
Old May 4, 2016 | 08:15 AM
Unreal's Avatar
Unreal
Work on shrouding.
The d3 dual PWM fan if you have a full size radiator works better than the single 17" so that is a great option.
Old May 4, 2016 | 09:00 AM
cwylie's Avatar
cwylie
What makes you say the dual setup from D3 is better than the single brushless from Dewitts?
Old May 4, 2016 | 09:52 AM
Unreal's Avatar
Unreal
Messed with both. The dual PWM d3 setup moves a bit more air than the 17", but it doesn't fit cutdown radiators, so I run the 17". With a TT setup I don't see why you would have a cut down radiator, so the d3 setup is the top choice.
Old May 4, 2016 | 10:10 AM
cwylie's Avatar
cwylie
What kind of mods did you have to do to make the d3 setup fit a dewitts radiator?
Old May 4, 2016 | 09:08 PM
Nino S's Avatar
Nino S
https://www.corvetteforum.com/forums/c6-forced-induction-nitrous/3799047-need-help-on-engine-temps-1k-hp-guys-please-help.html
I will update it this week. Since my changes I have not seen above 196 degrees with warmer outside temps then last month when I was regularly seeing 230+. Lots of time and work but it worked and I don't hate the car as much anymore lol
Old May 11, 2016 | 04:22 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Realcanuck mentioned it in that thread in the above link and I will echo it. An air gap between the rad/condenser and the intercooler help out a lot.
Old May 11, 2016 | 04:24 PM
Dude_man's Avatar
Dude_man
Removing that weather strip where the hood closes by the windshield made mine drop by 15*. I thought it was a joke until I tried it.
Old May 12, 2016 | 12:39 PM
Homeboy77's Avatar
Homeboy77
Okay, you have to elaborate. My car is a daily driver and I drive in the rain. Would it be safe to remove this strip? Yesterday, temp outside was 94. Just driving my temps went up to 240. When I hit bumper to bumper traffic, I had to turn off AC. That took me back to 230.
Old May 12, 2016 | 01:04 PM
Dude_man's Avatar
Dude_man
Yes it's basically just a cushion/seal for where your hood eats your cowling cover when it's closed. I thought it was a joke until I tried it.
Old May 12, 2016 | 01:20 PM
Homeboy77's Avatar
Homeboy77
I may try this. Thanks for the tip.
Old May 12, 2016 | 02:35 PM
Dude_man's Avatar
Dude_man
It takes about 10 seconds to remove too
Old May 12, 2016 | 02:45 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Won't hurt anything. You can spray the whole engine down with a water hose and everything will still be fine. Electrical connectors are sealed pretty well these days
Old May 12, 2016 | 02:50 PM
Dude_man's Avatar
Dude_man
I set up a sprinkler system in my engine bay, it kicks on after 190*.
Old May 12, 2016 | 02:52 PM
Homeboy77's Avatar
Homeboy77
Old May 12, 2016 | 02:53 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Win
To Warm Weather cooling
Old May 12, 2016 | 03:19 PM
Ls240sx's Avatar
Ls240sx
I went one step further and just removed the hood completely. The rain keeps my engine really cool. This combination has proven to work exceptionally well
Old May 13, 2016 | 12:19 PM
Nino S's Avatar
Nino S
fap fap fap fap fap
Old Jun 3, 2016 | 06:27 PM
Snowwolfe's Avatar
Snowwolfe
Did it help?
