C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
alky kit
Old May 8, 2016 | 04:28 PM
russ472's Avatar
russ472
Default alky kit
is there a difference in alky kits that use map vs maf signal inputs or are they the same and just use different sensors?
Old May 8, 2016 | 04:58 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I looked over the pictures of that one you were/are buying and it looks like the only difference is an adapter is included to convert the MAF signal (hz) to 0-5V. The rest of the kit looks identical as far as I could tell. Hopefully it is.. I'm almost sure it is
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Same other than the sensor.
Old May 8, 2016 | 05:00 PM
russ472's Avatar
russ472
thanks! I went ahead and took the chance and got it. Ill keep everyone posted in case it comes up for someone else.
the one I am getting is set up for MAF and I will just use my 3bar Map for signal.
Old May 8, 2016 | 06:44 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I would use the MAF if it's coming with the sensor.
To alky kit
