RecMech LSX427 F1x standing mile build
Received 1,194 Likes
St. Jude Donor '15
That is a lot of heat
Drivetrain... RPM built TR6060, ZR1 Rear, Mantic Triple, Quicktime Bell Housing, ZR1 Slave, Tick Adjustable Master, new GM Torque tube, DSS Couplerless shaft, ECS Brace...
Nice build. I like your steam vents
This is awesome and still a manual trans.
Brandon619 (06-01-2017)
#34
Dewitts cut down radiator with SPAL fans. ECS upper brackets, with the lower cradle cut and welded...
Chiseled Performance water tank in the rear. I thru bolted it to brackets welded to the frame rails.. I didn't want it to hit me in the back of the head in case of an accident!
Test fitting the intercooler..
#35
Intercooler piping.. Clocked the F1x to exit towards the center of the steering rack.. I will end up re-doing the throttle body pipe, it ended up with too long of a coupler. Maybe switch to a Vanjen clamp?..
Dual Tial 50mm bypass valves.. I do have parts for an air filter to snake next to the intercooler. . I have a dirt driveway, so some sort of filter would be nice just to get it on and off the trailer...
#38
Nice build, Looking forward to the results.
I got a couple test passes in the mile last weekend. 212mph took 25sec if I remember correctly.
This sounds like a mile run, Not a 1.5 mile run.
#39
