C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
RecMech LSX427 F1x standing mile build
Old 05-13-2016, 07:42 PM
RecMech
RecMech's Avatar
[QUOTE=Pekka_Perkeles;1592207720]Why not stick with stock E40 PCM?
I actually test fired it on the E38.. It wasn't happy!
Safety first!!
Old 05-13-2016, 07:56 PM
RecMech
RecMech's Avatar
Originally Posted by schpenxel
How long does a 1 or 1.5 mile run take?
175mph with 400hp took about 45 seconds in the mile and a half.
I got a couple test passes in the mile last weekend. 212mph took 25sec if I remember correctly.
Old 05-13-2016, 07:57 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
That is a lot of heat
Old 05-13-2016, 08:11 PM
RecMech
RecMech's Avatar
Drivetrain... RPM built TR6060, ZR1 Rear, Mantic Triple, Quicktime Bell Housing, ZR1 Slave, Tick Adjustable Master, new GM Torque tube, DSS Couplerless shaft, ECS Brace...
Old 05-13-2016, 10:06 PM
Slo-Poc
Slo-Poc's Avatar
Great builds and progress, I love my mantic triple so far. I about to order the pro efi unit also. Can't wait to see how all this turns out.
Old 05-13-2016, 10:54 PM
Mike Farris
Mike Farris's Avatar
Have you picked out a tire to run yet? Hoosier A7s maybe?
Old 05-14-2016, 12:36 PM
RecMech
RecMech's Avatar
Trying the R7 for now.. A7 was not available in the rear size I needed.
295/40R18 and 255/35R18 on CCW wheels. Tucked in a bit to keep them out of the air as much as possible.
Old 05-14-2016, 06:15 PM
C6 Curtis
C6 Curtis's Avatar
[QUOTE=RecMech;1592209789]
Safety first!!
what intercooler is that you're using?
-Curtis
Old 05-15-2016, 05:26 AM
venomws7
venomws7's Avatar
Awesomeness !!! Good luck man really looking forward for more I can't imagine spinning the F1X Through 6th 7500+ rpm
Old 05-15-2016, 12:35 PM
lt1z
lt1z's Avatar
Nice build. I like your steam vents
Old 05-15-2016, 02:07 PM
Detoxx03
Detoxx03's Avatar
This is awesome and still a manual trans.
Old 05-15-2016, 08:44 PM
ILLUSHN
ILLUSHN's Avatar
I'm in for narrow body support!
Brandon619 (06-01-2017)
Old 05-16-2016, 04:30 PM
  #33
RecMech
RecMech's Avatar
-Curtis[/QUOTE]
Chiseled Performance 2000hp. 4" vbands in and out. 1" water lines.
Old 05-16-2016, 04:39 PM
  #34
RecMech
RecMech's Avatar
Dewitts cut down radiator with SPAL fans. ECS upper brackets, with the lower cradle cut and welded...
Chiseled Performance water tank in the rear. I thru bolted it to brackets welded to the frame rails.. I didn't want it to hit me in the back of the head in case of an accident!
Test fitting the intercooler..
Old 05-16-2016, 04:46 PM
  #35
RecMech
RecMech's Avatar
Intercooler piping.. Clocked the F1x to exit towards the center of the steering rack.. I will end up re-doing the throttle body pipe, it ended up with too long of a coupler. Maybe switch to a Vanjen clamp?..
Dual Tial 50mm bypass valves.. I do have parts for an air filter to snake next to the intercooler. . I have a dirt driveway, so some sort of filter would be nice just to get it on and off the trailer...
Old 05-16-2016, 04:57 PM
  #36
vette4mud
vette4mud's Avatar
Wow! i love these build threads. sub'd.
Old 05-16-2016, 05:11 PM
  #37
SquirrelyNutz
SquirrelyNutz's Avatar
That is a nice intercooler! Can't wait to see this thing running, gonna be flying with that much power on a 1.5 mile run.
To RecMech LSX427 F1x standing mile build
Old 05-17-2016, 09:36 PM
  #38
gotjuice?
Support Corvetteforum!
gotjuice?'s Avatar
St. Jude Donor '13
Nice build, Looking forward to the results.
This sounds like a mile run, Not a 1.5 mile run.
Old 05-17-2016, 09:41 PM
  #39
RecMech
RecMech's Avatar
That is correct, I had parachute issues, so I was limited to the mile only.
Old 05-18-2016, 09:33 AM
  #40
RecMech
RecMech's Avatar
First time on the dyno...
Quick Reply: RecMech LSX427 F1x standing mile build
