MAP sensor, whats everyone using
Oct 3, 2016 | 12:50 PM
Car was on the dyno last week and evidently the MAP sensor failed. I was getting boost reading from the mechanical gauge, but the DashLogic would not read boost. it read vacuum but in boost. It simply read -0-.
So, any suggestions on a good MAP sensor. The one that I was using was a GM product.
Thanks.
Oct 3, 2016 | 02:00 PM
Doesn't sound like your map sensor failed, just sounds like your installer/tuner never put in the appropriate sensor and tune settings for the car to read boost.
Oct 3, 2016 | 03:10 PM
St. Jude Donor '15
I agree with Unreal.
What engine are you running?
LS2/7 I'd just get the DSX 2.5 bar sensor
LS3 a ZR1 sensor will work
Needs 2 values changed in tune regardless
Oct 4, 2016 | 04:18 PM
Quote:
Originally Posted by
schpenxel
Its an LS2 based 402 cid with a D1 ProCharger.
What is a DSX sensor? I searched Google and got nothing automotive.
Oct 4, 2016 | 04:23 PM
Modified 2.5 bar sensor for plug and play on earlier cars since ls9 sensor won't work.
Dave@DSX makes them.
Oct 4, 2016 | 04:30 PM
St. Jude Donor '15
http://www.dedicatedmotorsports.com/product_p/25bms.htm
There's also a GM 2 bar option, I think it's off a Cobalt, but I don't know the part number offhand
Oct 4, 2016 | 07:20 PM
St. Jude Donor '13
The DSX sensor makes things simple. Works great.
Oct 4, 2016 | 08:34 PM
I bought ZR1 MAP and IAT sensors for upcoming alky install.
Oct 4, 2016 | 09:54 PM
Which only work if you have a later model car.
Oct 4, 2016 | 09:56 PM
unreal
which only work if you have a later model car.
2008+?
Oct 5, 2016 | 08:49 AM
St. Jude Donor '15
Oct 5, 2016 | 06:20 PM
I switched from the Cobalt sensor to Dave's.
