C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Wheel alignment specs
Old Apr 17, 2017 | 12:37 PM
C6vettegfw's Avatar
C6vettegfw
Default Wheel alignment specs
Hey guys. I'm installing coil overs in the car soon. Drag racing season is just around the corner. For all you drag racers out there. Do you guys keep factory specs for your alignment or is there different specs you use for racing...
Old Apr 17, 2017 | 01:11 PM
95vettski's Avatar
95vettski
I keep factory specs for the front. In the rear zero camber and toe.
Remove the front sway bar and add the zr1 sway bar in the rear.
Every little bit helps.
Old Apr 17, 2017 | 01:33 PM
C6vettegfw's Avatar
C6vettegfw
what about when you go back to street use? Just back to stock settings? Do you keep the sway bar out? I would assume not.
Old Apr 17, 2017 | 09:44 PM
95vettski's Avatar
95vettski
That is my street set up
To Wheel alignment specs
