C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
lean tip in
Old Apr 29, 2017 | 07:43 PM
russ472's Avatar
russ472
Default lean tip in
I know this should be in the tuning section, but most of you tuner guys hang in this section more.
Wondering if when I get into PE, there is a delay before the fuel reacts. Just wondering if this is too long. If so, how to fix. This is a quick blast from rolling into boost in 3rd then into 4th. lean tip in is on both gears.
this is a 5 second capture
Old Apr 29, 2017 | 08:24 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
HPT is just in the process of adding a parameter that has proven to correct that for some people. It depends on the ECU version number.
There is an ongoing thread on HPT forum about it.
Old Apr 29, 2017 | 08:44 PM
russ472's Avatar
russ472
I saw the thread and disengaged the desoot function.
Old Apr 29, 2017 | 09:03 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Definitely wouldn't be happy with that spike. Probably have to see the tune to try and be of any help. Would also log and check fuel pressure to rule out any drop.
Old Apr 29, 2017 | 09:10 PM
ZincGT's Avatar
ZincGT
This is from that thread, they are working getting the function enabled in all of the ECUs
"Injector Enrich Desoot Mode". Under Engine > Fueling > General. Set it to disabled to correct mid wot lean issue.
Old Apr 29, 2017 | 10:20 PM
russ472's Avatar
russ472
see post #3
Old Apr 29, 2017 | 10:27 PM
russ472's Avatar
russ472
In that thread you guys are talking about, they were having issues with a lean spike exactly 2 seconds after PE.
My question with my log is... the lean spike immediately after PE is commanded, if mine is too long before the fuel system reacts. The log is literally zoomed in and the delay is 2/100 sec.
Just don't know if that is normal amount of time or not and if the delay could be how long it is taking for the wide band is taking to see the change and report it.
Old Apr 30, 2017 | 06:45 AM
Pekka_Perkeles's Avatar
Pekka_Perkeles
Assuming you have a lean spike:
- change the Enrichment Ramp In: max value
- PE delay: 1000 rpm or so
VERIFY by LISTENING the engine when suddenly going WOT. Please use appropriate knock headphones.
If there is still audible knock, then it will destroy your engine sooner or later.
Now, if there is still knock, then there are two options:
- play with transient settings
- switch to an aftermarket controller
Good luck!
Old Apr 30, 2017 | 06:57 AM
Pekka_Perkeles
Also, remove burst knock from the graph and use knock retard instead.
Old Apr 30, 2017 | 04:22 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Try increasing manifold volume 20-30% and see if it names any difference
Old May 1, 2017 | 12:20 AM
romandian's Avatar
romandian
where do you do that? (im on efilive, though.)
Old May 1, 2017 | 10:43 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Not sure on EFI Live, HPTuners just recently added it. It's in the transient fueling section for their software, not sure where it'd be on EFI Live though
Old May 2, 2017 | 10:20 AM
Pekka_Perkeles
Noticed it some months ago.
What is the reasoning behind it? Strictly for fighting lean spike? Only for E38 and E40?
Old May 2, 2017 | 11:01 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It seems to be kind of a "global" transient value that is really easy to change. Much easier than going through say the evap impact tables and trying to play with those and some of the other transient stuff. Transient fueling is such a PITA to mess with IMO.
Increasing it generally helps with lean tip in
It's only available on E38's unfortunately, they told me they couldn't add it on E40's
Old May 2, 2017 | 11:48 AM
Pekka_Perkeles
Thanks for that.
Now, it would be really nice to get a quarterly (or even twice per year) update of new features and relevant links with HP Tuners forum BY email AND with a specific discussion tread(s).
Like "Q2 2017 update of E38/E67 with desoot" and so on.
With not very active tuners and a new information, those tuning tricks will not be used just because they are unknown.
So talk with your superior, or give me a link. :-)
Too bad for you. :-(
Old May 7, 2017 | 05:16 AM
stevieturbo's Avatar
stevieturbo
"Tip in" generally refers to enrichment based on fast throttle openings.
Nowhere on that graph am I seeing a fast throttle opening ?
Old May 11, 2017 | 11:19 AM
TurboLX's Avatar
TurboLX
Silly question, but was this car calibrated in both MAF and "Virtual VE" using good steady state dyno data before chasing transient fuel control? The factory blended aircharge model is surprisingly good *IF* you populate both airflow models correctly. This alone goes a LONG way toward correcting most transient fueling issues on these cars.
Old May 11, 2017 | 06:29 PM
russ472's Avatar
russ472
it has an SD tune. It had a "tooner" mess with it on the dyno about a year and a half ago. Comparing the before and after tune, looked like he only adjusted PE and heavily desensitized my knock sensors.
Many changes have been done to the car since and I have done all adjustments on the street with help from time to time by other guys here on the board.
I appreciate any pointers you might have Greg.
Old Jul 16, 2017 | 01:08 AM
pannetron's Avatar
pannetron
7th Gear
FYI, the "injector desoot mode" is also visible on my crate engine E67 ECU.
To lean tip in
