C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
P0107 map code
Old May 23, 2017 | 08:33 AM
jusmillz's Avatar
jusmillz
Default P0107 map code
Does anyone know the what could be the answer to p0107 map sensor code? I just pulled my motor and replaced a piston, a nd this is the last code I'm dealing with. My c6 has an ecs kit with meth and headers.
Old May 23, 2017 | 09:27 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Same sensor as was previously on it?
Do you have any sort of scanner or logger so you can see what MAP value it's showing?
I'd check to make sure 5V is making it to the MAP sensor and also check what voltage it is outputting. That should give you a good idea where the issue is
Old May 23, 2017 | 09:40 AM
jusmillz's Avatar
jusmillz
yes it's the same sensor . I'm about to check a d see is my predator will allow me.
Old May 23, 2017 | 10:52 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
If not, pull out your multimeter.
Old May 23, 2017 | 11:17 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
That could be why you needed a piston.
Old May 23, 2017 | 11:32 AM
jusmillz's Avatar
jusmillz
I had no codes before the motor pull. I'm wondering what this black wire is used for.
Old May 23, 2017 | 11:34 AM
sevinn's Avatar
sevinn
Untape that mess and find out, share pics after as well. I'm going to venture to say that's your problem and that whatever is spliced in right there isn't working either.
Old May 23, 2017 | 11:42 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Alky control probably
Old May 23, 2017 | 11:47 AM
DOUG @ ECS's Avatar
DOUG @ ECS
To P0107 map code
