C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Car making low numbers???
Old Jun 2, 2017 | 12:55 PM
Patriot Six's Avatar
Patriot Six
Not sure what his engine specs are, but around 200 psi sounds about right.
Old Jun 2, 2017 | 02:09 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by Brandon Cole Hurdle
Yup. He tightened the gap on the plugs and has no more misfire. Seeing 13psi we have now made 650whp. Gonna add another degree of timing and see where we are but can't do that until we get the boost a pump figured out because it's not turning on and we have maxed injectors with fuel pressure dropping.
Good to hear, it doesn't take much to take away 100 hp.
Old Jun 2, 2017 | 07:23 PM
BlindSpot's Avatar
BlindSpot
If you're using copper plugs (like TR6s), the gap can be a challenge to hold.
Old Jun 3, 2017 | 12:21 AM
Brandon Cole Hurdle's Avatar
Brandon Cole Hurdle
Originally Posted by C U IN REARVEIW
What should compression be at? Ls2
mine were all around 220lbs with the highest being 238 on cyl 8
Old Jun 3, 2017 | 12:27 AM
Brandon Cole Hurdle
i believe they are tr7s they cam in the ecs kit. and the boost a pump is wired in between the fuse box and the fuel pump on the grey wire spliced into the harness.
Old Jun 5, 2017 | 12:27 PM
Ant-Man's Avatar
Ant-Man
Pushrod length, springs, plugs..
A shop didn't check pushrod length or gap plugs correctly when I had my blower installed and it caused the valves not to close properly, end result was lack of power, unnecessary pressure on the springs which broke a spring, bent a valve, kissed a piston. No more shops for me.
Old Jun 7, 2017 | 09:59 PM
Brandon Cole Hurdle
all said and done ended up at 660/560 so pretty good power I'm happy with it for now but y'all know how that goes lol. ill enjoy it for awhile then tear it apart and go bigger thanks for all the help and tips guys
