Are 60# injectors enough
And what fuel. E10, pure gas e85, ms109, vp c16
if you're spraying a good amount of meth you are probably fine but but 80lb injectors are so cheap seems kind of crazy at this point to not just get the bigger ones since you have to have it tuned anyway and then no issues and lower IDC. by the time you sold the 60lb injectors the net cost would probably be like $100 or less.
ID1050x and call it a day. Not cheap, but best injectors made with no issues, good data, good support, good service.
