C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Did I get a junk LS7 MAP sensor?
Old Jun 20, 2017 | 06:56 AM
jimxms's Avatar
jimxms
Default Did I get a junk LS7 MAP sensor?
Hi Guys,
I ordered an LS9 MAP sensor on eBay P/N: 12592525 for my S/C'd C7. Made the required changes in HP Tuners for it, and the car now refuses to start at all.
I pulled the sensor, looked inside the nipple and I can see a PCB, is this normal:
If I look at my original MAP sensor all I can see is a metal diaphragm.
Old Jun 20, 2017 | 11:50 PM
tuboy19's Avatar
tuboy19
Did you get the adapter harness? The wiring is different on the later (o ring style) MAP sensors
Old Jun 21, 2017 | 12:24 AM
Petraszewsky's Avatar
Petraszewsky
Yeah which wires are pinned into ABC/123 on the connector? If they're wired wrong it will not crank. I know because mine was wired wrong and I spent a couple of days trying to figure it out.
1-C
2-A
3-B
Is how my LS2 to LS3 sensor is pinned not sure if the LS9/LSA is pinned that way though.
Old Jun 21, 2017 | 03:58 AM
jimxms's Avatar
jimxms
1-C
2-A
3-B
Thanks for the pointer, I'll check that out.
This is actually for my boosted C7 Stingray. I thought I'd post in the C6 forum because you guys have probably used the LS9 sensor a lot more.
To Did I get a junk LS7 MAP sensor?
