C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
dash logic issue
Old Jul 23, 2017 | 11:06 PM
sm0kinvette's Avatar
sm0kinvette
Default dash logic issue
Bought a dash logic unit to view air/fuel and boost. The problem I am having is when I press page to view other things it does not show them. Just goes back to track mode, ect
The dash (DIC) is stuck on hp/torque
the software is 1.21
Old Jul 24, 2017 | 08:56 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Try a newer version of the firmware. This is a link that was posted on another thread on the board last year:
https://www.dropbox.com/s/lgdlu7mjmo...20fix.ehx?dl=0
Also, your hud should be in street mode for the dashlogic to work. I never had any luck with 1.21...it would crash every 2 or 3 minutes.
Old Jul 24, 2017 | 09:41 AM
sm0kinvette
Yeah works on street mode only but only displays the first page then if I try to change page it goes back to the gauge display.
I will try the newer firmware once I get home. What version is it? 2.0?
Old Jul 24, 2017 | 11:54 AM
Chiselchst's Avatar
Chiselchst
I'm using 2.02, and I started having having it drop out, increasing in frequency. Now it works maybe 30% of the time, no pattern just random. Just goes out like it was unplugged.
Good luck...
Old Jul 24, 2017 | 07:00 PM
sm0kinvette
Updated the firmware to 2.02 or 2.2 whatever it is and it still has the same problem. great way to spend $300 lol
Old Jul 24, 2017 | 07:54 PM
BoostedOne's Avatar
BoostedOne
You need to press the door lock button to cycle through the dashlogic "pages". They will all display in street mode on the HUD
Old Jul 24, 2017 | 09:55 PM
sm0kinvette
Thank you very much !
Old Jul 24, 2017 | 11:53 PM
Mike's LS3's Avatar
Mike's LS3
... and the mirror button to select exhaust mode with NPP.
Old Jul 25, 2017 | 12:19 AM
Detoxx03's Avatar
Detoxx03
Not to hijack but I recently got one and have been messing around with it. Does it actually read HP and TQ for you guys or do you have to activate something for it to work? Same for other things like 0-60, lateral g's etc? I have boost, gear change, temps, and some other stuff working. Also I thought it read ethanol content as well.
Old Jul 25, 2017 | 07:46 PM
sm0kinvette
Anyone know what formula that I would have to use for a AEM UEGO wideband (30-4110)?
The calculated boost pid on dashlogic is working but not sure how accurate it is. Anyone know the formula for a gm 2/2.5 bar map sensor?
Old Jul 25, 2017 | 08:14 PM
Mike's LS3's Avatar
Mike's LS3
No, but the 3 bar ZR1 sensor: Linear 312.50 kpa Offset -11.25 kpa
Old Jul 26, 2017 | 08:27 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Voltage / 0.5 + 10 would get you in terms of AFR for gasoline on that wideband
The boost PID is as accurate as the ECM has data for. It's displaying the same thing the ECM is seeing.. so if it's wrong then the ECM is seeing it wrong too. It should be very accurate.
To dash logic issue
