C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E85 week end warriors
Old Aug 3, 2017 | 07:35 PM
croatbob's Avatar
croatbob
Default E85 week end warriors
If you drive your car on week ends and always run e85. Is storing all week with e85 in the tank a concern? How long would you sit a car with e85 in the tank before it's a concern with corrosion and gunk?
Old Aug 3, 2017 | 08:11 PM
slow ride's Avatar
slow ride
Not that I would, but my friend leaves it in all winter lol. Haven't had a fuel related issue yet. His car is a Rx7 with metal tank also. I have yet to have a problem in the last 2 years, but I purge the system with pump gas over winter.
Old Aug 3, 2017 | 08:16 PM
croatbob's Avatar
croatbob
Im in south Florida so I drive year round. If I was storing it due to travel is fill it with pump but I drive it every week so not sure e85 is an issue for me?
Old Aug 3, 2017 | 09:49 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
My car is a race car. I only drive it on the weekends. The fuel sits in it all week or two or three...
I have E85 in a drum in my shed. It sits there all winter and in the spring I go right back out and get after it!
Old Aug 4, 2017 | 11:49 AM
Detoxx03's Avatar
Detoxx03
I have met mine sit for months without issue. Maybe it's cause I changed everything over for E85.
Old Aug 4, 2017 | 01:25 PM
ksurfer2's Avatar
ksurfer2
Kind of a hijack....As I understand, it is possible to run both e85 and gas by switching tunes. However, how do you manage this with what is in the tank? Is it necessary to completely empty the tank of gas before adding e85 (and vice versa)?
Old Aug 4, 2017 | 01:56 PM
Unreal's Avatar
Unreal
Flex fuel, no tune switching. Car automatically adjust anywhere from pure gas to 100% ethanol. Just fill up and enjoy.
Dsxtuning.com for flex fuel kits.
Old Aug 4, 2017 | 05:20 PM
FNBADAZ06's Avatar
FNBADAZ06
I've let mine sit for several months without any issue, but I'm also in a much drier climate than Florida (I'm in AZ).
High humidity states your shelf life for ethanol fuels are shorter as the fuel absorbs the moisture in the air. I'd feel comfortable letting my car sit for a few month in your state, but would consider filling the tank with standard pump fuel if it was to sit for 3 months or longer just to be safe.
Old Aug 4, 2017 | 07:24 PM
Unreal's Avatar
Unreal
I can't remember the last time I had pump in my car. Probably 4 months ago. Never had issues.
Old Aug 5, 2017 | 09:59 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Same, mine has sat for about a month before without any issues. I’d try to stick with stainless injectors if buying new (ie ID’s X line) but I’m running regular ol ID1000’s and they’ve been fine
To E85 week end warriors
