LSx Boost Happy intake manifolds
#202
Just put about 15 mlies on it. All good.
And final install picture all wrapped up.
#205
Former Vendor
Pretty little CTS-V Intecooled heading out the door.
$2750 for these
We are also going to start making our own rails so no more having to mod Holley rails.
G1Pro Rails will be $200 for -10 and will already be modded for each application (shortened and plugged by the cowl for c7, mods of that nature)
$2750 for these
#206
Originally Posted by Unreal
Rewired map sensor, since adapter wouldn't work.
Had to pull one header off since a nut fell down into collector and wouldn't come out. No fun.
Manifold is now on and torqued. Have to completely redo the FPR setup, so just ran lines to the fender and will have to deal with that later when lines/fittings show up.
#207
The required holley high ram rails. The only ones that work with this intake.
#208
#209
Ask James, he knows when you order the intake.
#210
Pretty sure it's the 534-224 rails for the LS7 version at least.
https://www.holley.com/products/inta.../parts/534-224
#211
Searched my summit orders and that is correct.
#214
Originally Posted by G1Pro
Holley EFI Fuel Rail PART# 534-224
#216
If anyone is interested in a G1Pro LS7 Vette Intake Manifold I listed mine for sale here:
https://www.corvetteforum.com/forums...post1596445794
#217
https://www.youtube.com/watch?v=PnfL_fMm5aM
#218
Made 1118 with a bad miss up top from plugs being gapped way too big. Based off curve/etc I would guess 1150ish if plugs weren't breaking up. That was CPRs dyno. Made more than that on UMSs dyno in the past, but different dyno, different day, etc.
Running it tomorrow at 1/2 mile. That will be the real test.
#219
Made 1118 with a bad miss up top from plugs being gapped way too big. Based off curve/etc I would guess 1150ish if plugs weren't breaking up. That was CPRs dyno. Made more than that on UeMSs dyno in the past, but different dyno, different day, etc.
#220
