Heat exchanger 4 SC
What kind of boost are you running? What kind of outside air temps did you run it at? Was it tuned on the dyno or on the street? Was it just peaking at 140* at the end of the run or was it heat soaking and staying at around 140*?
I don't know who your tuner is, but I don't agree that 140 is "too hot". I would say that it's quite typical, actually, if we're talking about the inlet air temperature ("IAT"), not the temperature of the supercharger. It all depends on how and under what conditions you're seeing that IAT. If that's the IAT at the end of a dyno run, and you're running 7+ psi in 85+* outside temperatures, then I would say that your tuner is mistaken if he thinks you can drop 20* by just changing the HX. If that's possible, I want one of those myself!
Of course, you could always put a methanol/water kit on it and that would drop your temps a lot, but unless you figure out a way to spray meth directly on the IAT sensor, it might still not drop down that much, because on a PD blower, with the typical setup the meth/water mixture still has to go through the rotors, plenum etc., before it gets to the intake ports. The added octane from the methanol would keep the engine from knocking and would allow more timing to be used though.
I'm running the Magnuson Heartbeat and I was seeing ~138* at the top of 4th gear @ ~ 12psi, with the stock HX system, and by just adding a Moroso expansion tank in the battery box (after relocation the battery to the right rear cubby) I managed to get the temps to drop by about 12*.
I have a stock ZL1 pump that I'm going to use to upgrade the standard Bosch one, to see if that makes a difference as well.
See data logs below: top one was in May and the other in December. That doesn't make much of a difference down here though (both days actually had almost identical weather:~86* outside temp):
What was the ambient temp when you saw 140*F?
Are you monitoring IAT's with a Dashlogic while driving? Mine - when moving >40 MPH - are always ~12-15*F above ambient. Then of course they go up after a hit. I'm running ~8/8.4 lbs boost, and mine typically don't go up by more than 10*F after a pulling thru a couple of gears.
My car definitely loves cooler weather. When my IAT's are <100*F it runs noticeably better...
Personally mine doesn't see 140*F unless it's parked hot, then re-started after 20+ minutes of sitting. But it quickly drops back down after it's re-started. Hence, I'm under 100*F IAT's 85% of the time.
That looks nice I like that...I just want to drop temps cuz I do want to pulley down later on. I'm looking which HX are better then what I have to help with this heat on the SC. My buddy was telling me to get a icebox but I don't know
You running the E force as well? I'm gonna see if the new HX,Flex Fuel and maybe a meth kit will help enough
. I just don't know which HX to look at
BTW: are you sure it's the HX itself that's the problem, or is it that you're not getting coolant circulated fast enough through the charge air coolers? Remember, like everything else, it's a system which works based on the sum of all parts, so if your pump is weak, or for whatever reason, you're not getting good flow through the CACs, then it won't matter what kind of HX you put up front, it won't make much difference.
Thanks for the info man...but when I got the car tuned the flow was good and everything it was circulating properly, but it was running alittle hot that's why he required me to get a better heat exchanger to keep temps down. It was pulling timing on high RPM's like 2 degrees when he showed me if that makes sense
I have no doubt that your HX system is circulating properly, but that doesn't mean that, like everything else, it can't be improved upon. The advantage of an expansion tank is the added coolant capacity - as well as the ability to add ice - and it has been pretty much proven that there are better HX pumps out there than the standard Bosch pumps. The point I'm making is that it might not be the HX alone that's the problem. Do a bit of research on here and other forums before you buy one, because the aftermarket ones are pretty expensive.
Yup that's the plan man just trying to find info on what's my best bet to keep temps down some people have told me about the icebox and a meth kit but idk yet. I will be doing the flex fuel for sure that be the next mod to do but like u said I don't want to buy another HX and it does the same thing lol so I'll do more research hope I find the problem so many options just hard to decide unless I find a badass HX that for sure it will solve the problem then I'll buy that lol
