On3 Turbo Build
#261
I use to move the rack, but I find it easier now to drop the cradle. Put a jack under the oil pan and unbolt the rear k member bolts until the last couple threads. I take off the front bolts completely and then if you need too you can use the jack to lift the motor a couple more inches.
#263
Exactly, just use something to disperse the weight of the motor over the pan and you'll be fine. I've done this on many different cars and much heavier motors. I wouldnt leave it sitting like that overnight but just to support it for a short time I dont see it being a problem. As stated above, just be smart and mindful of what youre doing and you shouldnt have any problems. In this case its saving a ton of time. You could always use an engine hoist to hold the motor up, too, if you have one.
#264
What did you decide to coat the manifolds with? I'm trying to decide if I'm going to go that route as well. Didnt think these turbos would be such a bitch to get on so now im tempted to just coat them now instead of experimenting with underhood temps and then having to remove them down the road.
#265
Received 2,832 Likes
2021 C6 of the Year Finalist - Modified
.....soooo.... what's the latest g23?......
#266
Pro Mechanic
Received 3,952 Likes
better that YOU asked that question................
I was hoping he would have come back and posted measurements from cam journals and bearings............ but G23 seemed more resolved to have the whole engine gone through from some of his earlier posts related to pressure loss...........
#267
Car hasn’t been touched for awhile celebrated my 23rd birthday last weekend and leave for the Bahamas next week. Going to try and get the cam mic’d in the next couple days but haven't had much time to work on it.
#268
...yeah...you better stay home and work on your car......I will take that Bahama duty for you......... just trying to help out......
#270
As relieved and as embarrassed I am, I finally figured out my oil pressure issue. After accepting the fact that my motor most likely needed rebuilt I went to prep it for removal last night. As I went to remove my intake valley cover I noticed that all of the bolts were only hand tight. So after torquing them down I turned the engine over a few time and the pressure jumped straight up. Put everything back together and fired it up and what do you know... 50 psi at idle 65+ while revving. Pretty embarrassed I wasted so much time on a mistake like that, but I guess this is one of those learning moments.
#271
#272
....life has many such lessons Grasshopper....... Glad you found that glitch...... now on with the build.......
#275
Received 1,194 Likes
St. Jude Donor '15
Better than a new motor!
#276
Got most of the car put back together, need to plumb the waste gates this weekend. Would like to try and get my exhaust started, or at least get the x pipe on. Not sure what I want to do for the over axle part yet.
If anyone see a decent set of injectors for sale, let me know. Thats kinda the last piece of the puzzle.
#277
If you don't mind used, check the GM truck forums out. I used to see sets for sale on them all of the time. It's been a while since I visited since I got rid of my Avalanche aftet 14 years and bought an F-150.
#278
#279
One problem after another, now the turbos are pushing oil into the exhaust. Turbos are brand new, they have restrictors on them. The lines were seeping so I bought all new an lines and fittings, was going to make new lines tonight so I’ll have the turbos off anyways. Hopefully I’ll be able to see the problem.
#280
I totally understand the frustration this can cause. Just make sure the oil return line is higher is high enough for the oil to return to the pan. I had a car with a kinked hose and it wouldn' allow the oil to return and that was the reason for the turbos smoking.
