Getting ready to pull the trigger on either a E-Force or Magnuson Heartbeat. Anyone care to share the pros or cons of each system before I make this jump.
I have the eforce on a ls2 vette. The torque on them is insane. Not as familiar with the Magnuson however I am not dissapointed with the eforce kit what so ever
I am still in the fence on either one, I also tend to factor in future problems that may or may not occur. Such as upgrades, used/new parts, rebuilding and and so on. I do however prefer the looks of the lid cover on the heartbeat but I can not base my buy on looks alone and looks are in the eye of the beholder. So far from my research and still reading up when I can.
E-Force pro's:
1. less modification from factory to install and to revert back to stock
2. provided coil covers for cleaner looking install at less expense
Both seem to be good units. My eforce was great. Never had a HB.
I like the HB look but would go eforce because it’s clearly more upgradable. We all want a bit more eventually !!
I like the double roll look on the HB lid but leaning towards the E-Force. If a used system pops up at the right price before the end crazy day sales than either will do.
They both use Eaton TVS2300 rotor packs. No difference there. Probably either will do you a fine job. I've had three Magnuson TVS2300's that have served me well. One crapped out after "only" 250,000 miles. Didn't run the others that far.
Have never owned an EForce. Only thing I can tell you is what my tooner told me. He mentioned that he didn't have to wait much between dyno pulls for cooling with the Heartbeat...where he did have to wait with the EForce. That would matter to me. It may not to you.
I probably won't supercharge my current C6 because I'm an old fart and my reflexes probably can't keep up with that kind of power any more. If I did, I'd have a Heartbeat on the way.
Update since I haven't posted as to witch direction I went. I ended up getting the e-force 544hp kit with a 3.50 pulley and a z06 fuel pump and doing my own install. In hindsight I wish I would have done a cam swap, fuel pump, injectors, headers and a pulley swap at the same time of the install. I am running the can tune that came with the kit and have not tackled the fuel swap to down size the pulley as of now. Having the original tires with 2,500 miles on then didn't have any grip before the install wouldn't help after the install. Having said that I have to make judgements on the e-force from a rolling start that I hate doing. I get my thrills from a dead stop as in running the 1/4. For my liking coming off the line I need grip so I need to find better tires, a6 with 2:73 if some are wondering. Getting into it from a rolling start I am not impressed with the 544hp kit, my first reaction was gee that's it - a lot of money for little gain. The install wasn't all that bad to do even though it was done without a lift. I have been contemplating the z06 fuel pump-pulley upgrade since day one and haven't done it with the lack of having a lift so a lift is also on my list of wants. I didn't install the heavy weight covers but here is a pic of one of the cars some has said would be better off parted out.
