C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
My build for 2018
Old 07-20-2018, 09:53 AM
  #161
Tech
Tech's Avatar
18mmx1.5 male o-ring to -6an. Its the o-ring side that is leaking.
Old 07-20-2018, 10:00 AM
  #162
g23crawler
g23crawler's Avatar
Im sure you have already tried everything but I had a 18mmx1.5(o-ring) to 10an fitting leaking on my oil scavenger pump and switch to a BSPP thread with a copper washer(like on a banjo bolt) and it stopped the leaking. I would think the rack is a metric tap or npt tap and not a BSPP (straight threads) but it may be worth trying.
Old 07-22-2018, 03:13 PM
  #163
Tech
Tech's Avatar
I went to Harbor Freight and bought every size and material o-rings they have. So far, two have failed, but at least one was just a sizing issue. I can't quite figure out the other. Does anyone have their rack out of the car (or the engine out) and can take a picture of the high pressure inlet on the rack for me? It looks like mine has a black o-ring in the bottom of it, but some light touching with a pick didn't cause it to move. I don't want to go poking around and damage something that isn't supposed to come out this way.
Old 07-22-2018, 03:31 PM
  #164
MickOpalak
Banned Scam/Spammer
MickOpalak's Avatar
What about brakes / suspension / aero / safety equipment? What are you going to do for those upgrades?
Old 07-23-2018, 10:03 AM
  #165
Tech
Tech's Avatar
For what I'm using the car for, all of the stock stuff is sufficient except tires. I just had R88Rs installed but I haven't been able to drive the car much due to the power steering leak I'm battling.
Old 07-24-2018, 09:46 AM
  #166
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Old 07-24-2018, 10:44 AM
  #167
Tech
Tech's Avatar
Thanks Unreal. I think that looks just like mine. Wonder which brand fitting you're using. I ordered two new fittings from Summit. One made by Aeroquip which looks roughly the same as what I have, and one made by KRC which has a cone shaped end on it, like the factory lines.
Old 07-24-2018, 04:33 PM
  #168
Unreal
Unreal's Avatar
When I get home later I'll see if I can find it. Whatever the DP kit came with.
Old 07-24-2018, 05:07 PM
  #169
Tech
Tech's Avatar
The A&A fitting looks like an off brand or possibly an Earl fitting. These are the two I ordered. The A&A fitting looks like the Aeroquip in terms of design, but it has a shiny finish like the KRC. The factory line has a cone-shaped end like the KRC fitting.
https://www.summitracing.com/parts/aer-fbm2609
https://www.summitracing.com/parts/krs-krc10123000
Old 07-24-2018, 05:20 PM
  #170
jayyyw
jayyyw's Avatar
I ordered some fittings from JEGS. Not sure what brand they were. I don't run a pump anymore so I couldn't tell you if they would leak under pressure or not.
Old 07-25-2018, 11:24 PM
  #171
Tech
Tech's Avatar
I feel like Dubya saying this again, but mission accomplished. The KRC fitting looked like the best fit and my power steering is no longer leaking. To my surprise, the Aeroquip also had a cone shape but the ID of that side was significantly smaller than the other two.
KRC
Aeroquip
A&A fitting with harbor freight o-ring
Old 07-25-2018, 11:26 PM
  #172
Tech
Tech's Avatar
Aeroquip (middle) had a much smaller opening
Old 07-27-2018, 03:23 PM
  #173
Tech
Tech's Avatar
The car is at CBI Street Cars for a Fore fuel system. It will have triple 450s plumbed in series with rail mounted regulator, Fore rails, flex fuel sensor and the FlexLP -8 lines everywhere but the last couple of feet going to the tank (those are PTFE). I hope to have it back next week. Baby is due a week from tomorrow, so who knows if I'll get to drive the thing.
Old 08-10-2018, 04:29 PM
  #174
Tech
Tech's Avatar
The car is back. Fuel system seems ok. Power steering is leaking, again. I haven't verified if it's the same spot, but I have little confidence it's somewhere else.
Old 08-10-2018, 04:54 PM
  #175
Patriot Six
Patriot Six's Avatar
Is the car tuned and running and you’re just dealing with the leak still? I hope you can get that sorted out. I know how frustrating that has to be.
Old 08-10-2018, 06:57 PM
  #176
Tech
Tech's Avatar
I’ve put about 300 miles on it now. Most of those trips were cut short though because of the leak. I need to sort out the idle and start with flex fuel. I may drop the car off with Steck for that because my daughter arrived last week.
Old 08-10-2018, 07:15 PM
  #177
Patriot Six
Congrats. Hopefully, you can take her for a ride soon. Lol
To My build for 2018
Old 08-20-2018, 03:28 PM
  #178
Tech
Tech's Avatar
Idle is sorted out. Partial throttle stuff is done. I'm using the Aeroquip fitting. 3 trips out with ~2 hours total driving while tuning and I haven't noticed any leaking.
Old 08-20-2018, 04:47 PM
  #179
chpmnsws6
chpmnsws6's Avatar
Famous last words
Old 08-20-2018, 05:12 PM
  #180
Tech
Tech's Avatar
You don’t have to completely ignore power steering leaks, but it helps.
Quick Reply: My build for 2018
