C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
meth charge pipe
Old Feb 12, 2018 | 09:59 PM
veloz's Avatar
veloz
Default meth charge pipe
gaging interest on my charge pipe design..will come with relocated MAF , Meth nozzle and IAT bungs welded to an alum pipe, will offer it mill finish, vinyl wrapped or powder coated...any thoughts?
Old Feb 12, 2018 | 10:15 PM
Unreal's Avatar
Unreal
Vinly will come right off, and maf placement looks poor.
Old Feb 13, 2018 | 01:41 PM
veloz's Avatar
veloz
why is MAF in poor location...?
ive tested vynil under the hood and it has stayed on
Old Feb 13, 2018 | 03:27 PM
Unreal's Avatar
Unreal
That pipe gets way hot. Easy 200+. I can't see vinyl staying on for long. Even paint bubbles off after awhile.
Considering you don't have a bend in there, looks like maf is right after the bend for the FMIC. You want as much straight pipe before the maf as possible to reduce turbalence and get a good maf reading. .
Old Feb 13, 2018 | 04:10 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
MAF placement is so critical, for our C7 kit we made a ton of different designs before we found the one that gave the least turbulence.
Old Feb 13, 2018 | 04:38 PM
veloz's Avatar
veloz
right on,,i got about 2-3" of straight pipe before the bend..i got some room for moving it away from that bend but not much. guess wont know until we put it on the dyno... dyno is in about 1 week..il post results..
not too worried about the vinyl...i once wrapped the coil covers with it and lasted over two years on a daily driver...but wel see..
Old Feb 13, 2018 | 04:39 PM
veloz's Avatar
veloz
this is one is for a C6Z with a procharger...dont know if that makes a difference
Old Feb 13, 2018 | 10:05 PM
silver408z's Avatar
silver408z
He was just referring to how important it is to get in the right place. So important they kept changing their kit. The model of car was not the point of his post.
Old Mar 25, 2019 | 08:53 AM
veloz's Avatar
veloz
so for all the skeptics, happy to report that after more than 1 year of testing, plus daily drives and track events this charged pipe has performed flawlessly. Vinyl still looks brand new, there have been no leaks, no code engine errors, just working awesome. many thanks to charles braber - V8muscle and brandon shannon for his fabrication skills.
Old Mar 25, 2019 | 02:13 PM
renegade123's Avatar
renegade123
That vinyl would most likely melt on mine...your states with lower summer time temps may not be so brutal on it. Looks cool though. It is amazing how cool real carbon fiber remains. I have dual Scorpion Pipes on my race bike ( Ninja 1000 ) , and those things are almost cool to the touch 5-10 minutes after beating the snot out of it at 170 plus mph
Old Mar 25, 2019 | 10:28 PM
HouseS2k's Avatar
HouseS2k
i have a procharger on my C6Z and I have meth kit with a ls9 iat I want to install soon. How much do you sell these for? Can you add a 2nd bung for duel nozzle? Pm me.
Old Mar 27, 2019 | 08:27 AM
EnginerdVT's Avatar
EnginerdVT
What alcohol nozzles do you use in the bung that welded onto this pipe and do you have any pictures of this populated with them? I'd definitely think you'd want less space between each item to give you more space from the front bend at the IC, but it sounds like you're having decent real-world results.
Old Mar 29, 2019 | 12:04 PM
veloz's Avatar
veloz
i was made from scratch.you tell me what you need and we can fabricate it. you can pm with info
Old Mar 29, 2019 | 12:08 PM
veloz's Avatar
veloz
i have the Cooling meth kit, il post a picture today. the pipe length available was limited so i had to put them where they were. there is about 4" of straight pipe in front of the MAF. and i wanted the temp sensor to be as far away from nozzle as possible but also as far away from MAF. soo this is where it all landed..so far its been awesome...
Old Mar 30, 2019 | 09:33 AM
veloz's Avatar
veloz
Default Pic
To meth charge pipe
