C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
SCT-4X programmer SC question
Old Mar 4, 2018 | 05:34 PM
mikecronis's Avatar
mikecronis
Default SCT-4X programmer SC question
Installed an Edelbrock e-Force Stage-1 which comes with an SCT-4X ECU programmer which has a "gauges" function like a DashHawk.
The SCT-4X programmer has a sort of boost-gauge as Manifold Pressure in PSI. This is connected to the OBD-II port while the engine is running.
I noticed that at idle I'm at about 4 PSI, when decelerating I'm at 2 PSI, and WOT I'm at 15.75 PSI.
Somehow I'm thinking that this is not the boost produced by the SC. Is this correct? I think not since maximum boost should be 8 PSI and related to engine RPM, not throttle response.
The stock tune has already been imported to the unit and supposedly installed. I have no CELs and the car pulls fairly nicely.
IAT got to be 95 F deg. even though it was 60 F. outside, according to the unit. What's too high an IAT?
Old Mar 4, 2018 | 05:36 PM
Unreal's Avatar
Unreal
It is, just have to subtract out atmospheric.
Old Mar 4, 2018 | 05:57 PM
mikecronis's Avatar
mikecronis
Ah, I see. Because it's "absolute" manifold pressure. Working it out, I think it ends-up being around 7 PSI boost at 6000 feet altitude?
Old Mar 4, 2018 | 06:24 PM
Unreal's Avatar
Unreal
Sounds about right.
To SCT-4X programmer SC question
