C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
methanol injection
Old Mar 16, 2018 | 07:30 PM
sm0kinvette's Avatar
sm0kinvette
Default methanol injection
Hello,
I have a stage 3 methanol kit from snow performance. I have been thinking of installing because I would like to cool the intake temps and possibly help the engine a bit. I have taken care of the head valve issue already.
I have a ls7 with full bolt ons, blower cam and a v3si at 7psi(4" pulley). 705hp/630tq.
What do you guys think about adding a mix of 50/50? will the power increase from the meth make the engine a ticking time bomb?
Old Mar 16, 2018 | 08:41 PM
Patriot Six's Avatar
Patriot Six
With the proper tune, you'll be fine. I would only run 100% meth.
Old Mar 17, 2018 | 02:40 AM
Detoxx03's Avatar
Detoxx03
Alky Control with 100%
Old Mar 17, 2018 | 08:36 AM
Unreal's Avatar
Unreal
This
Old Mar 17, 2018 | 11:36 PM
EnginerdVT's Avatar
EnginerdVT
I have an LS7 with similar items (V3 T Trim blower)... 93 pump gas + Meth. Alky Control system works great and definitely cools IATs as well as helps with octane. Definitely wouldn't push a stock bottom end LS7 without it or going E85.
Old Mar 18, 2018 | 09:45 AM
Ant-Man's Avatar
Ant-Man
Ran 93/tiny bit of 100% meth and made 704 @ 8psi
Renegade 100% is what I run, decently cheap and good stuff.
Old Mar 18, 2018 | 07:37 PM
grocerygetter's Avatar
grocerygetter
AlkyControl and 100% VP meth. Get it.
Old Mar 19, 2018 | 01:43 PM
veloz's Avatar
veloz
i use 50% and it works great..AIT dropped 30 deg..less hazardous and no need to keep cans anywhere and have to mix it...u can get mixed meth from snow performance or you can get -20 deg windshield washer fluid but its only 30-40% meth,,,
Old Mar 20, 2018 | 09:47 PM
RMcoolX's Avatar
RMcoolX
So what is the advantage of 100% vs 50/50? I currently have an LS3 with V3 Si and ARH pushing 550whp on 93oct. I'm getting an Alky and smaller pulley installed next month and my tuner is suggesting 50/50. My goal is another 80+ whp, but at the same time I want a fairly fail-safe meth setup. Is that the advantage of 50/50?
Old Mar 21, 2018 | 03:09 PM
bumpin96monte's Avatar
bumpin96monte
My setup was less prone to knock with 100% meth. I started with a 3.8" (v3si) on 50/50 (boost juice) and my tuner couldn't run as much timing as he would've liked. Switched to 100% meth and a 3.6" and he was able to get the timing up where he wanted it and the car picked up a good bit of power.
Old Mar 21, 2018 | 03:21 PM
Patriot Six
You'll get more octane out of 100% meth and still get the cooling benefits. Octane is key to preventing detonation. Any slapping around of the pistons on a stock LS7 and the motor is toast.
Old Mar 22, 2018 | 02:45 PM
veloz's Avatar
veloz
what timimg did u end up at?
Old Mar 30, 2018 | 01:38 PM
typeav's Avatar
typeav
Snow Performance 50/50 works fine for me, after all I want is cooling and octane benefit. This is the right tank to go with, you can place it in the trunk with the pump to keep it cool away from heat.
Old Mar 30, 2018 | 03:23 PM
Detoxx03's Avatar
Detoxx03
I run that same tank and love it. Keep 100% in mine though.
Old Mar 30, 2018 | 03:50 PM
sm0kinvette
for you guys running 100 meth are you using nylon lines or stainless steel reinforced lines? just wondering because I ve heard100 perceny meth is very flammable.
I have a 2 gallon tank that I plan to mount in the rear.
To methanol injection
