C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost reference FPR install
Old Jul 1, 2018 | 11:23 AM
Dyekid04's Avatar
Dyekid04
Default Boost reference FPR install
Have the ECS stage 2 fuel kit with AE1000 secondary. About to put on boost reference FPR on it 1:1. I want it to stay stock pressure but increase when boost comes in. Is that achievable without dropping the tank and putting the block offs in?
i have a full return going on with it, i just like to do it without dropping the tanks again if it will work just fine.
Old Jul 1, 2018 | 04:29 PM
Pete2k_Z28's Avatar
Pete2k_Z28
I’m in the same boat as you are right now I will be bolting on a supercharger soon and would like to go with a boost reference regulator. I know the UPP system does have a return line but I’m not crazy about drilling and tapping into the tank, I like the ECS set up a little better, just seems a little more secure, and that is important when it comes to holding 15 gallons of a highly flammable liquid from leaking out of my car.
Old Jul 1, 2018 | 04:33 PM
Pete2k_Z28's Avatar
Pete2k_Z28
The way UPP does it is a tap the return back into the line coming out of the tank between the tank in the fuel pump. I’m not sure if the line sizes etc. of the ECS system would allow you to do that as well.
Old Jul 1, 2018 | 07:21 PM
Pete2k_Z28's Avatar
Pete2k_Z28
So I just picked up my ECS 1500 kit and in talking to the previous owner who has the ECS fuel system there is apparently a an extra bung to run a return if you wanted.
Old Jul 1, 2018 | 08:03 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Yes. There is a return on it.
Old Jul 2, 2018 | 03:12 AM
GaragedLS2's Avatar
GaragedLS2
Meh, I have one on my car and have had 0 issues with leaks. The bulkhead they supply is pretty nice and seals well. Just throw some threadlock on the allen screws and you shouldnt ever have a problem. That and make sure to smooth out the area around where the bulkhead seals to the tank. Its a bit of a pain to get on but still 100x easier than dropping the tank.
My understanding of running an aftermarket FPR with reference, is you'd need to use the block offs if you want the siphon pump to work properly. I was told to leave my reference port open as to not have any issues. If you never run lower than the base pressure, though, I'm not so sure it would be a problem.
Old Jul 2, 2018 | 09:10 AM
Unreal's Avatar
Unreal
Problem is you pull a vacuum, and it lowers the pressure at idle and low load, so depending on your setup, how much vacuum you pull/etc, you may not have a working siphon at idle/etc. Which will throw a code, flip the car out, etc.
I told him he could maybe put a check valve so the FPR only sees boost, and only raises pressure, while keeping stock 58psi.
Old Jul 2, 2018 | 09:34 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I’ve heard of people connecting the vacuum connection pre throttle body, that way is never sees vacuum (ie never reduces fuel pressure) but sees boost and increases fuel pressure accordingly. I’ve never done it but a very respected shop/tuner gave the idea
Obviouslu you’d have to know how to set the fuel injector data up properly in the tune in order for this to work properly
Old Jul 2, 2018 | 01:49 PM
Unreal's Avatar
Unreal
Which would work on a PD blower car, not on a centri.
Old Jul 2, 2018 | 03:12 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Tell Bret that, he does it on centri setups.. not sure why it wouldn’t work on those too though?
Old Jul 2, 2018 | 03:41 PM
Unreal's Avatar
Unreal
Yah, I'm wrong, but should still see vacuum there. Maybe not a ton, but enough.
Old Jul 2, 2018 | 04:14 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
yup,that's EXACTLY how he has told me to set mine up....he is in the middle of tuning mine now and ZERO issues
Old Jul 2, 2018 | 04:18 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Interesting concept. Maybe try it one day. To be honest mine has been non referenced for a few years now and there are no issues that way. Everything works as it should.
Old Jul 2, 2018 | 08:18 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yeah, I just did mine non referenced too honestly, though if you had enough fuel pump but were tight on injector DC it is a way to get around that without dropping the tank
Old Jul 10, 2018 | 01:34 AM
Corvettepower11's Avatar
Corvettepower11
Might try this cause I'm trying to get out of dropping tanks also
Old Jul 10, 2018 | 06:16 AM
Dyekid04's Avatar
Dyekid04
Y would you run a regulator but not Boost reference it im confused . I thought the deal was for it to help with fueling under boost?
Old Jul 10, 2018 | 09:19 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
You can still set pressure with it and run a return, even if not boost referenced. If you have enough pump and injector you can keep the AFR's where you want them without referencing.
To Boost reference FPR install
Old Jul 10, 2018 | 09:35 AM
Dyekid04's Avatar
Dyekid04
Ahh i was under the impression if you dont block the stock regs it just always stays at 58psi? Basically you cant go lower or higher. I figured without the reference the only thing you get out of it is just a return style.
Old Jul 10, 2018 | 09:51 AM
Corvettepower11
I am truly glad you shared this info with us
Old Jul 10, 2018 | 10:15 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
That is right. It will stay at 58 psi, or whatever you set it to.
