C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fuel systems
Old Jul 6, 2018 | 01:17 PM
Corvettepower11's Avatar
Corvettepower11
Ok I'm going with fic 1200cc but I do plan on going with a boost reference regulator. I guess I'm have to break down and except the fact I'm have to drop my tanks
Old Jul 6, 2018 | 01:19 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
If you connect for boost reference, then yes....
Old Jul 6, 2018 | 01:20 PM
Corvettepower11
Ok thank you sir I'll get with Doug on the block off
Old Jul 7, 2018 | 01:31 AM
RMcoolX's Avatar
RMcoolX
Yep, drop those tanks. A recently failed performance shop tried to go the secondary pump route on my car and it cost me a new gas tank. Spend the money now to avoid regrets later!
Old Jul 7, 2018 | 03:13 AM
corvettepower's Avatar
corvettepower
Are u saying drop tanks to do block offs or a in tank pump
Old Jul 12, 2018 | 04:25 PM
tac328's Avatar
tac328
just dont buy the UPP system. its a bag of random parts with no instructions aside from a youtube video that was filmed using a potato. Also they give you the wrong fittings - cut up an fittings instead of ORB An fittings. *barf*
Old Jul 12, 2018 | 07:42 PM
Ant-Man's Avatar
Ant-Man
Yea honestly the upp system is odd, but for $700 and maybe 700-800hp it'll work fine. I don't like how they recirculate the hot fuel back through the pump though rather than to the tank to cool off a bit.
I started with a upp system which worked OK but I re-did mine with dual AEM 400 inline pumps, -8 feed -6 return. All in all I've prob spent like $1200 on fuel parts with $700 of that being the UPP kit.. it's worth it to do some research and piece together your own system. I have my tank tapped for a -12 feeding dual -10 feeding the pumps and a -6 return. The feed is excessive but I don't want to strain them for fuel.
Also -strictly based off calculations- two 400lph pumps at less than ideal flow 'should' feed 1300+ on E85.
Old Jul 21, 2018 | 01:28 AM
Corvettepower11
Can u post a pic of your -12 splitting to dual -10s
