dart shp ls next block oil starvation issues
I have a 427" dart shp ls next block with dart cnc ported heads and a ysi-b blower. car is suffering from extreme oil starvation during a pull. oil pressure will drop to 10psi in seconds. engine has stock c6 pan and a standard volume melling oil pump.. I have tried installing a restrictor to limit top end oiling as I thought it was sucking the pan dry. no change thoughts??
