Guess my dyno numbers! Add a restrictor?
Received 1,194 Likes
St. Jude Donor '15
St. Jude Donor '15
Or pistons, etc. designed for more power to begin with so they don't go boom at the first sign of knock.
Some use dual plugs, higher displacement, lower compression, etc etc. I don't keep up with much other than the GM world but it is def crazy what some cars are doing straight from the factory these days.
St. Jude Donor '15
What was the correction factor then? That blower should do about 1200 CFM's. 837 at the wheels seems high.
SAE J1349
uncorrected and loaded it made 867whp/729wtq but I’m not really concerned with any of that, it’s damn fast that’s for sure. Now I need to work on “driver mod” seems to be what needs the most work lol
https://www.corvetteforum.com/forums...nd-thanks.html
dyno sheets and video are posted on a thread in the ZO6/ZR1 section. Here’s a link
SAE J1349
But it is what it is.
Seems to be similar to old dyno numbers on the car before I bought it and did the rebuild, so what are you saying is odd specifically?
still needs an auxiliary fuel system, the RPM’s are @ 6600 and we kept a 6800 rev limiter as well.
Well the numbers are finally in! We ran up against the clock today so I didn't have time to get a dyno graph (yet) but at the end of the day we made 756 / 697 @ 10 lbs on the ECS 1500 with stock pulley and no restrictor with 93 + meth. I couldn't be happier with the results and the car drives like stock, just with a LOT more power! Huge thanks to Joe @ Powertech Performance, Julio @ Alky Control, Gil @ A&S Motorsports, and the crews @ Vengeance Racing, Fore fuel systems, Monster clutch, and of course ECS for all of your help and support on this build!
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,090 Likes
Well the numbers are finally in! We ran up against the clock today so I didn't have time to get a dyno graph (yet) but at the end of the day we made 756 / 697 @ 10 lbs on the ECS 1500 with stock pulley and no restrictor with 93 + meth. I couldn't be happier with the results and the car drives like stock, just with a LOT more power! Huge thanks to Joe @ Powertech Performance, Julio @ Alky Control, Gil @ A&S Motorsports, and the crews @ Vengeance Racing, Fore fuel systems, Monster clutch, and of course the ECS for all of your help and support on this build!
That's great! I can feel your excitement through your post, enjoy!!
#33
congrats! good numbers and you can probably still throw more boost at it with that forged bottom end
#34
Nice numbers! Heard good things about Powertech. The guy I bought my car off of had them do the work on it.
Makes me wanna up the boost on my ecs1500!
DOUG @ ECS (01-17-2019)
#35
Throw some video up man! Let’s hear this bad boy make some noise!
