Cutting open the front bumper ?
#41
Just came across this thread. Don’t know how I missed it.
https://www.corvetteforum.com/forums...installer.html
#42
Ship your car to Georgia for it? Problem with Tikt stuff is in house install only.
#43
True. But to tell you the truth, looking at what they do, I don’t know if I would ever want to take on that kind of cosmetic surgery myself. And I don’t even wanna guess the grief and money it would cost me to ship my car back to the States. At that rate, I might as well buy a new car and ship it to VR. Mind you, that thread (and the new ZR1) made me realize that the looks of the C7 can be improved. Maybe I should buy a C7 Z06 and get VR to build the **** out of it?? But then I would need a new garage, home, wife...lol!
#44
But, I gotta say, THIS is dead sexy:
#45
I agree that laying the radiator forward and venting the hot air through the hood like the C7 does would be the best way to get the additional airflow for the cooling that an FI car needs. I the think the proper way to do that would be to remove the front boxed steel bumper and the foam nose support and build a tubular bumper/nose support with the necessary bracketry for the rad, intercooler etc. hanging on that, such that the radiator leans forward, enabling airflow through it from both the nose opening and the underside of the nose put through the hood. There’s a lot of room up front once you remove that big *** boxed bumper and the foam. Additional airflow through the nose would be a bonus (but might not even be necessary) as long as it can be vented through the hood (or fenders) to reduce front end lift at high speeds. But all of that is more than I’m willing to take on, lol.
There is also rear mounting a second rad. Some race cars do it. Just have to think about the exhaust routing. Could mount it’s in front of the rear licence plate and fees from the rear wheel arches. Also seen people put trans coolers behind the rear wheels.
#46
If been fighting high coolant temps since I finished my turbo setup. So far, I’ve done: wired fans direct to power with relays, wrapped my exhaust, wrapped closest coolant pipe to the exhaust, added track spec hood vents, and cut a good amount of my crash beam. I made up some shrouding out of cardboard and duct tape and also added the flap under the radiator like the stock setup to try and create a low pressure area behind the radiator. The shrouding and the flap showed the biggest improvement in my coolant temp while cruising. Just today I transferred the cardboard shroud pieces I made onto sheet metal. I went from 217-223 temps in 85 degree weather, to 187-194 temps at 70mph. Haven’t been able to test the car by doing pulls yet but I’m hoping to see a significant difference there as well.
#47
#48
Drove the car to work this morning. Same drive, before, would reach 199 by the time I got to the gate. I was chilling at 187, at the gate.
#49
#51
I've always run straight distilled and a bottle of water wetter and temps seem to always be in a good range. I know our setups are different, but yesterday it was 96* here and with an iron block saw water temps around 201 in stop and go traffic and I wasn't even running the shroud that goes above the radiator. I also don't have a/c which helps a lot with flow thru the radiator. Glad to see your temps seem to be in a good range now. Do you have separate coolers for trans and oil? I removed trans lines which were integrated into my radiator and just looped them, they were so close to the header pipes that I think any cooling was mitigated by that.
#52
#53
Platinum Supporting Vendor
Hey guys, we were linked over to this thread from our Local Corvette club. We have been looking into some options to make a front bumper for the C6 that would increase the airflow and have side openings to run additional coolers.
We just have a couple questions.
- Would most of you guys be open to cutting the crash to be able to get more airflow in?
- Would you guys want side inlet options to allow for running more coolers etc..
Any input is greatly appreciated!
#56
#59
Are you guys looking at doing a full bumper cover? I have seen the cooling ducts and canards.
#60
