C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Another what to do Thread ;)
Old Jun 12, 2019 | 07:21 PM
pyrodav's Avatar
pyrodav
Default Another what to do Thread ;)
So, I have been saving for a little while and have a $10K budget. 2010 GS m6. I have MPSS, LT's, BB Fusions and a Halltech. The car dyno'd at 410. I want 650 eventually, not necessarily this budget time though. My thoughts are to get the car ready for the bigger power now and A&A later. UNLESS you guys can steer me in a different direction.
I'm thinking... 1st buy a Mcleod RXT clutch and install. 2nd get my car switched to E85. 3rd buy some r888r tires. 4th get a Jam Cam. 5th get the A&A. (I know I can't do all that for 10k)
Or am I completely backwards...get the blower and e 85 and pray my clutch and tires hold and get a cam later.
Old Jun 12, 2019 | 07:36 PM
da6speed's Avatar
da6speed
Not sure about the clutch situation as I have an auto.
But, I would do cam & blower at same time, reason being there is some overlap in labor you could save if you're paying a shop to install. The steering rack and balancer is going to have to come off both times to do either (unless you don't plan on having an 10% lower), so just do that once.
Old Jun 12, 2019 | 09:15 PM
Unreal's Avatar
Unreal
Just have the crank pinned while the cam is done, then that isn't an issue anymore.
I like your idea. Do the support first, then add the other parts.
Old Jun 13, 2019 | 09:34 AM
VVVROOMTX's Avatar
VVVROOMTX
I would suggest going to a blower like a ECS1500 over a A&A. Easier belt setups and more cfm than the T trims
Old Jun 13, 2019 | 09:46 AM
da6speed's Avatar
da6speed
ECS 1500 and A&A Ti are the same blower A&A don't even sell the old T-trim anymore.
Old Jun 13, 2019 | 09:58 AM
VVVROOMTX's Avatar
VVVROOMTX
A&A's website says the max CFM for the v3Ti is 1250cfm and 22lbs, ECS1500SL says 1400cfm and 26lbs
Old Jun 13, 2019 | 10:57 AM
Unreal's Avatar
Unreal
Then it is wrong. It is exactly the same compressor wheel.
Old Jun 24, 2019 | 08:27 PM
pyrodav's Avatar
pyrodav
Thanks for the input. I decide to do RXT clutch, Jam Cam, and E85 conversion along with rear r888r's and leave my MPSS up front.
In a couple months I will throw the blower on. Im at 410 whp right now. Any guesses what Ill hit after the first stage before the blower?
Old Jun 24, 2019 | 09:06 PM
Chiselchst's Avatar
Chiselchst
I'll be your huckleberry...
My guess is ....40 hp for e85, and 35 for the cam...not knowing the specs LOL (on E85) RWHP at 485. Mine did ~90 whp better on e85 over 91 octane (AKI), with a cam, ported heads and 10# boost...
My opinion, worth what you paid for it...
Old Jun 24, 2019 | 09:34 PM
pyrodav's Avatar
pyrodav
Nice...are you on just e85 or meth too?
Old Jun 25, 2019 | 12:51 AM
Chiselchst's Avatar
Chiselchst
e85 only
Old Jun 25, 2019 | 07:45 AM
Innovate's Avatar
Innovate
Blower and be done, you can make the power with a used $5k blower kit. Go E for the benefits and grab a Mantic Twin.
To fill out the $10k, cam/pin crank.
Old Jun 25, 2019 | 12:51 PM
davered00ss's Avatar
davered00ss
A&A kit with Meth and a good clutch can be done for $10K That will put you over 600rwhp (3.8 pully), if you go with a smaller pully, you will hit 650.
Old Jul 16, 2019 | 08:40 PM
pyrodav's Avatar
pyrodav
Well, things didn’t go as planned. Things have gotten out of control. I went with E85 flex fuel sensor, DSX ZR-1 fuel pump kit. zR-1 map sensor, MM catch can, RXT clutch, Jam Cam kit and BTR Trunion kit, A&A t-trim blackout kit with 3.6 pulley. Already have headers 3” exhaust with BB fusions. R888r’s.
Something tells me my car won’t be quite the same when I pick her up in a couple weeks.....of course now I’m wondering where my WHP and Torque will be. Any guesses now?
Old Jul 16, 2019 | 09:47 PM
Patriot Six's Avatar
Patriot Six
710/640. In for results.
Old Jul 17, 2019 | 10:40 AM
pyrodav's Avatar
pyrodav
I would be very happy with 710/640.
Old Jul 17, 2019 | 06:09 PM
harleyreb1's Avatar
harleyreb1
725-740 is my guess if that fuel pump kit will support it
To Another what to do Thread ;)
Old Jul 17, 2019 | 06:43 PM
Dimewise's Avatar
Dimewise
630whp if mustang dyno on 93, add 50whp if on E
Old Jul 18, 2019 | 06:02 AM
pyrodav's Avatar
pyrodav
What makes you question the fuel pump?
Old Jul 18, 2019 | 09:40 AM
harleyreb1's Avatar
harleyreb1
E85 requires a good bit of fuel and I’m not familiar with a DSX zr1 fuel pump kit.
