C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Injectors?
Old Jul 30, 2019 | 05:48 PM
Spaceme1117's Avatar
Spaceme1117
Default Injectors?
I have an Edelbrock E-force on my 2011 Grand Sport. Will eventually get a blower cam to go with it but I will also need to get bigger injectors when I do.
I see that Tick has both 65 lb and 85 lb per hour FAST injectors on sale. I think the 65 lb injectors would be plenty but would the 85 lb injectors be more future proof in case I decide on further mods down the road for more power? Or would these be too big?
Old Jul 30, 2019 | 11:38 PM
LeifAshley27's Avatar
LeifAshley27
I’m on a eforce with heads and a cam (Lingenfelter 670 package).
I would seriously look at going with something e85 compatible just in case. I’m looking at ID1050x now as I’m topped out now.
Old Jul 31, 2019 | 12:10 AM
LOURDESBELLE's Avatar
LOURDESBELLE
2025 C6 of the Year Finalist - Modified
Default Injectors
I have A&A V3Si Trim. It came with 60# injectors, but decided to upgrade to 80#ders for peace of mind.
Old Jul 31, 2019 | 02:04 AM
WestCyril's Avatar
WestCyril
Always leave room to grow with injectors and fuel pump.
Id go with 80/85lbs or even a ID1000 or 1050x like mentioned
Old Jul 31, 2019 | 09:15 AM
pyrodav's Avatar
pyrodav
DSX flex fuel kit. FID1000 injectors is something else to consider. I needed more pump with e-85 so I went with DSX ZR-1 kit and had it turned down and bought a ZR-1 sensor. It turns on and off with boost not a Hobb switch. My tuner has had multiple Hobb switches fail on the Dyno so we went that route. Good luck
Old Jul 31, 2019 | 09:40 AM
Spaceme1117
I think I want to stay away from e85. The availability in my area is rather slim. Also, I have in my mind a goal of around 600 whp so I don't think e85 would be necessary.
I am going to go with the 85 lb/hour injectors. Should be plenty of fuel flow for my goals.
Another question: The tuner is about a 2 hour drive from me. Would I be able to change out the injectors and then drive to the tuner? I assume that the injectors would be spraying more fuel because of the larger flow rate. If that is the case, then other than running rich would there be any danger to driving the car without adjusting for the larger injectors?
Old Jul 31, 2019 | 11:15 AM
CHR89's Avatar
CHR89
I would go with another brand injector personally. Lots of people have issues with FAST injectors, I have personally experienced problems on my own car along with others that I work on in the past. ID/FIConnection/FID are a few I would look at well before FAST.
Also I would recommend just changing the injectors in the parking lot at the tuner or changing them and towing the car there.
To Injectors?
