C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Map Sensor
Old Aug 14, 2019 | 01:12 PM
vetteOnTheRun's Avatar
vetteOnTheRun
Default Map Sensor
Ok Im a newbie to forced induction but im going to ask this question anyway: will the wrong MAP sensor cause your Absolute Manifold Pressure to read high? Causing your tuning software to calculate your boost way higher than it really is? I installed a supercharger and had it tuned. I was doing some data logging and noticed that my boost was more than double than what i expected. I checked the formula in HP tuners and it is correct. I also checked the barometric pressure and that appeared dead on, but the absolute manifold pressure I think is way high causing the boost level on HP tuners to read way high. I put 2 different mechanical boost gauges on and they both read within the range i expect. So this leads me to believe that I have the wrong MAP installed? The tune I have installed is a 3bar ZR1 tune. Please dime in and advise please. Oh BTW the car runs fine, maybe a little rich. Thanks
Old Aug 14, 2019 | 04:13 PM
Creamo3's Avatar
Creamo3
Is it reading about 14.7 psi higher than expected?
Old Aug 14, 2019 | 04:32 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I have a Heartbeat supercharger on my LS3.
The kit comes with an LS9 Manifold Absolute Pressure (MAP) sensor ... GM P/N: 12592525
You need the LS9 MAP sensor in boosted applications.
The Mass Air Flow (MAF) sensor used is the OEM stock LS3 'blade type' sensor ... no need to change.
Old Aug 14, 2019 | 05:14 PM
vetteOnTheRun
Somewhat close to that (14.7)
Thats what I am thinking. Ill check that part number. Also the tune is speed density.
Old Aug 14, 2019 | 07:24 PM
Turbo6TA's Avatar
Turbo6TA
The LS3 MAP sensor has a black colored label on it.
The LS9 MAP sensor has a red colored label
Here is what the LS9 (3 bar) sensor looks like, with it's red label ...
Old Aug 15, 2019 | 06:23 AM
vetteOnTheRun
Thanks turbo. Im pretty sure this is the issue.
Old Aug 15, 2019 | 07:54 AM
Al_Scrap's Avatar
Al_Scrap
You need to remove 14.7psi cause we have 1 atmosphere on earth
Every 6.9 kPa over 101, is 1 PSI
A 3bar map sensor in reality can only read around 30psi on your car.
Old Aug 15, 2019 | 04:36 PM
Creamo3's Avatar
Creamo3
Exactly - absolute pressure includes atmospheric pressure. I believe the value you want to use is Calculated Boost
Old Aug 16, 2019 | 06:31 AM
vetteOnTheRun
Thanks for the input. My new Map sensor will arrive today. I will likely install it tonight after work. I will post up my results. If everything goes good my next step will be looking for a good tune using HP Tuners for my A6.
Old Aug 19, 2019 | 06:29 AM
vetteOnTheRun
The ZR1 MAP sensor fixed my problem. Thanks guys!
To Map Sensor
