C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Is anyone running this gauge setup?
Old Jan 16, 2020 | 02:52 PM
~STOLEN~'s Avatar
~STOLEN~
Default Is anyone running this gauge setup?
I cant across this on marketplace, and seems pretty cool alternative to a pillar pod. I already have the SLP single pod on the left of the cluster with my AFR gauge in it, i would just like to add 2 more for Fuel/Boost maybe e85 contect etc. My only questions is how much it reduces airflow on those 2 vents. I love my A/C so i dont want to loose too much flow.
Another thing i thought about was if that very cold air and hot hear would cause the gauges to condensate or fog on the lense. I dunno, maybe im over thinking it.
What do you guys think??
Old Jan 16, 2020 | 03:03 PM
sonnysucks's Avatar
sonnysucks
you will literally lose all airflow brother. I have an innovate ECB1 holesawed above the vent on the left of the steering wheel. Single gauge has afr, boost, fuel temp and ethanol content.
Old Jan 16, 2020 | 03:09 PM
~STOLEN~'s Avatar
~STOLEN~
Dammit......I figured as much...
I even thought about making a couple v shaped baffles to wedge behind the gauges to direct the air around them.
I do have a question about that ECB1 while i have your attention though. Since i already have a Flex sensor for the car wired to pmc, can you just tap into that white line for the gauge to read content , or do you guys literally have 2 flex fuel sensors in your fuel supply line? seems redundant to me.
Sounds like I'll just sell my stand alone AFR and put a ECB1 in to simplify everything
Old Jan 16, 2020 | 03:35 PM
sonnysucks's Avatar
sonnysucks
Nope, tapped the flex fuel white wire as you stated. ECB-1 is nice, previous owner bought it adn my MAP sensor died, but got a replacement quick and wired it up, no problem. I added a weather pack at the end of the wire that comes into the engine bay for MAP sensor replacements though, it's hard wired all the way from the gauge (from what I saw) and that's kinda dumb.
I shouldn't say it'll block all your airflow, but it will block a significant amount and i was always not excited about super freezing my gauges with AC and super heating them with heat all the time? I also find its' kinda hard to look center console when driving? sorry, kinda a **** photo but you can see it there.
Old Jan 19, 2020 | 12:07 PM
jayyyw's Avatar
jayyyw
If you switch to a single din radio, you can fit 3 guages in the cubby with a little work.
Old Jan 21, 2020 | 09:05 AM
~STOLEN~'s Avatar
~STOLEN~
Man, i love my DD, i dont think i could go without it having installed the entire system just last winter. I'm right on the cusp of a street car vs race car. This current build may be the tipping point
Old Jan 21, 2020 | 01:35 PM
Creamo3's Avatar
Creamo3
I had the vent setup, but later on ditched it in favor of just running DashLogic. The vents didn't allow much airflow and really didn't have a solid way to mount the pod.
Old Jan 23, 2020 | 10:29 AM
~STOLEN~'s Avatar
~STOLEN~
Hey, thanks for chiming in. Its a really cool idea, but with the humidity and temps here in july/aug......i GOTTA have those vents LOL
i may have to go super Fast and Furious and do the Ole pillar pod like the old days. Never been a fan of the HUD, i have had it off since the day i bought the car, i literally just turn it on sometimes to make sure it still works.
the other option was the steering column bezel, but i cant get that damn mickey mouse comment out of my head after reading that thread hahah
Old Jan 23, 2020 | 01:24 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Dash logic will display on the DIC as well, not just the HUD
Old Jan 23, 2020 | 02:33 PM
theandrewo's Avatar
theandrewo
Humidity will not be an issue, as running the AC removes the humidity (thus why your AC comes on automatically when using the defroster).
I would also assume temperature wouldn’t be an issue. Ambient temps in the car range as low as the temperature outside (during the winter), to 130+ during the summer.
I think your real debate is whether you wanna give up those 2 vents.
To Is anyone running this gauge setup?
