C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Plenum pressure?
Old Mar 12, 2020 | 11:52 AM
Charliemopic's Avatar
Charliemopic
Default Plenum pressure?
If your boost gauge indicates 10 psi at full boost under full load does that mean 10psi is all there ever is in the plenum?
I say yes.
I want to mount a small clear window, a view port of sorts on an Edelbrock supercharger plenum cover or lid.
A friend suggests that will not work bcuz the pressure in the plenum would be too great to contain.
I have plexiglas from .250" to 1.0" thick.
In my humble opinion, the only pressure (or vacuum) we see in the intake tract is what is indicated on the vac/boost gauge.
Thank You
Old Mar 12, 2020 | 12:06 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Gotta ask ... what do you plan on seeing when you look through this little plastic window you want to install ?
Is the plan to cut a hole in the top of your aluminum supercharger lid and then glue this plastic 'window' in there ?
Not trying to belittle you or anything like that, but this seems to me to be a mod where you are just going to ruin a perfectly good supercharger lid ... bad idea in my opinion
Old Mar 12, 2020 | 08:51 PM
Chiselchst's Avatar
Chiselchst
I agree - plus there's absolutely nothing to see...and it will either a) leak, or worse yet b) fail
ETA; Unless you want to see the supercharger rotors?
Old Mar 13, 2020 | 07:07 AM
Spaceme1117's Avatar
Spaceme1117
I say yes.
Thank You
Terrible idea to do this for a bunch of reasons.
But if you really want to do that, it would be better to replace the entire lid rather than cut a window.
One thing to remember also is that while 10 psi, is not a large amount of boost, the total amount of force applied to the lid is significant.
Remember it is 10 pounds per square inch. The E-force lid is about a square foot maybe a little more. So 10 psi by say 150 square inches for 1500 pounds pressing on the lid. Can plexi withstand that and can it take heat?
And another major problem is thermal expansion. Just looked it up and plexi has a thermal expansion coefficient 4 times that of aluminum.
Just not a good idea.
Old Mar 25, 2020 | 12:27 AM
Shortpersonbk's Avatar
Shortpersonbk
even ignoring the pressure issue the heat will be a big issue
That lid is going to expand and contract. The glue will melt and what ever plastic you find will more then likely warp from the temp of the lid/engine bay temp. I do not believe plexiglass needs a very high temp to be soft enough to move around with very little pressure and in this case sag in the middle.
Trying to think back to a plastics processing class i took not too long ago i also believe that although resistant to having physical property changes via heat cycles that in this use it would still be heat cycled so often that it would eventually probably have issues. I wouldnt be surprised if eventually it cracked and fell into the blower or something like that.
Old Mar 26, 2020 | 01:17 PM
TTZ06VETTE's Avatar
TTZ06VETTE
Yep...not a good idea for all the reasons above plus a possibility of overboost condition past 10PSI that would magnify the issues.
Old Mar 28, 2020 | 06:44 AM
stevieturbo's Avatar
stevieturbo
I say yes.
Thank You
Exactly where on the blower ? On the inlet side of the rotors would only be vac or atmospheric pressure. On the engine side, there would be positive pressure as well as vac at times depending on throttle/load etc.
But securing any window, the heat, removing structural rigidity etc of the blower would all be concerns
Although how much of the lid is contoured around the rotors etc ? Is a flat window/lid even any option at all ?
Old Mar 28, 2020 | 09:28 AM
Turbo6TA's Avatar
Turbo6TA
stevie ...
I think the OP gave up on his crazy idea ... he hasn't been back to this thread since he started it 2 weeks ago
Old Mar 28, 2020 | 10:23 AM
CI GS's Avatar
CI GS
I assumed from the get go that this fella was just yanking our chains?
Because, obviously, other than watching the rotors turn when you’re standing alongside the car with the hood up and engine idling, this kooky idea serves no utility or entertainment purpose, and promises a lot of trouble in return.
BTW: The lid on an Edelbrock E-force is only going to see boost once the bypass closes.
Now he has thinking that maybe I would like to install a couple of fiber optic cameras through the lid of my blower, aimed at the spray bar, just to see how the nitrous is flowing during a run...
To Plenum pressure?
