C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Reinstalling pinned balancer
Old May 16, 2020 | 08:00 PM
russ472's Avatar
russ472
Originally Posted by White07
I always use a longer dowel pin. Its like 4" long. Lines up perfect every time
sounds like a good idea now, but when i drilled it, i definitely wasnt thinking i would be pulling the balancer off on a regular basis.
Old May 23, 2020 | 06:08 PM
jimbob8915's Avatar
jimbob8915
Originally Posted by CI GS
Another option would be to get a machine shop cut the 1/2-round drill hole through the full length of the bore of the balancer (like a half-round keyway). That way, you could set the pin on the crank, then slide the balancer on, line it up to engage the pin and then tighten the balancer down from there, just like you would with a key.
This ^^^. This is what I would do. I have a ATI dampner and when I pull my motor apart for new pistons I am going to have a machine shop cut a key slot into my crank.
